Input level conversion
rnielsen
PostPosted: Fri Apr 06, 2007 12:14 am     Reply with quote
I have a device that runs on 3.3V. It's output is feeding a device that is running on 5V. The 5V device's spec. sheet states that it's input is a Schmitt Trigger and needs a minimum of 4V to see a high level on it's input.
This might seem to be a simple one for some but my brain has turned to mush since I've been trouble-shooting this one for a while and finally realized what my problem was. I didn't realize the input needed to be so high. Does anybody have an easy idea of how to convert the 3.3V device's output to go higher than 4V?
Ronald
PostPosted: Fri Apr 06, 2007 12:34 am     Reply with quote
See my post on 3.3v to 5v level conversion in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=23154
libor
PostPosted: Fri Apr 06, 2007 4:29 am     Reply with quote
There's a very good summary on all these 3V-5V level issues, called 3V Tips and Tricks on the Microchip website.
3V Tips and Tricks
PostPosted: Fri Apr 06, 2007 9:57 am     Reply with quote
MAX3371. Bidirectional translation without the need for a 'direction' control input.
rnielsen
PostPosted: Fri Apr 13, 2007 9:33 am     Reply with quote
I tried out the MAX3371 and it works great. Tiny little buggers, though. I had to use a magnifying glass to see what I was doing.
Thanks for the tip.
Ronald
