Markdem
| Relay making PIC stop |
Posted: Wed Mar 28, 2007 4:54 pm |
Hi All, i have tried to make a light conntroller that is controled using MIDI commands. It all works very well, but when i connect anything to the relays, eg to the 240VAC side, the PIC will stop about 2 sec later. Nothing happends if i unplug the light. I have tried to use diffrent devices on the 240 side, but it does not help.
The only thing that i can tell is it must be somewhere between when the PIC recived that data, and when i try to decode it, as PIN_E0 will be on when it stops.
The relays are powered off a diffrent power supply, and are connected via a darlington array.
Can anyone see why this may be happening??
Thanks, Mark
#include <18F4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,NOBROWNOUT
#use delay(clock=48000000)
#use rs232(baud=31250, BITS=8, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#define USB_CON_SENSE_PIN PIN_D1
#include <STDLIB>
#include <usb_cdc.h>
int1 MIDIDataIN;
int BeatStep, i, Loutput, Qcount;
int MIDImsg;
int BeatMask[35];
#int_rda
void MIDIBeatIn()
MIDIDataIN = 1;
output_low(PIN_E0);
MIDImsg = getc();
void SettingDownload()
disable_interrupts(INT_RDA);
printf(usb_cdc_putc,"200\n");
for(i=0;i<32;i++) //get Beat Masks from host
BeatMask[i] = get_int_usb();
BeatStep = 0;
enable_interrupts(INT_RDA);
BeatStep = 0;
MIDIDataIN = 0;
QCount = 0;
for(i=0;i<32;i++)
BeatMask[i] = 0;
usb_init_cs();
usb_task();
if (usb_cdc_kbhit())
switch(get_int_usb())
case 200:
SettingDownload();
case 201:
for(i=0;i<32>= 24) //Has 24 clocks gone, meaning that is is a beat
printf(usb_cdc_putc,"BEAT!!\r\n"); /////Testing
QCount = 0;
loutput = BeatMask[BeatStep];
output_b(Loutput);
if(BeatStep >= 31)
BeatStep = 0;
BeatStep++;
output_high(PIN_E0);
Markdem
Posted: Wed Mar 28, 2007 5:41 pm |
| Thanks PCM, i forgot to say that i have back emf diodes installed |
rwyoung
Posted: Thu Mar 29, 2007 7:38 am |
How much current does your relay's coil require for pull-in and also for hold?
How are you driving the coil? Direct from the pin (generally bad idea) or with some kind of buffer? _________________ Rob Young
SherpaDoug
Posted: Thu Mar 29, 2007 1:58 pm |
It sounds like the PIC works as long as nothing is connected to the contacts of the relays, but a load on the relay contacts makes the PIC stop. In that case the problem is not on the coil side of the relay. I would look at the proximity of the 240VAC wiring to the PIC, and maybe add some snubber caps to the relay contacts. _________________ The search for better is endless. Instead simply find very good and get the job done. |
