How to decode X10 in CCS C
pete
PostPosted: Tue Mar 27, 2007 5:33 am     Reply with quote
Hi there!
Can you post a code in CCS C how to decode an X10 signal? I know x10 first sends 1110 then house code then function code then 3 cycles pause and repeats the same pattern. I just want to decode the function code and lit an LED corresponding to this function code. I'm aware that transmission is just after the zero crossing detector of AC line and there is a format in transmiiting a "1" and a "0".
THanks...
dyeatman
PostPosted: Tue Mar 27, 2007 5:45 am     Reply with quote
You can find the CCS versions in the CCS example and driver directories. You still have to have the X10 powerline interface.
