grasspuddle
garbage data on usart |
Posted: Mon Mar 19, 2007 8:46 am |
When I use a simple fprintf like :
fprintf(SW_UART,"S");
OR
fprintf(SW_UART,"%C%C%C%C%C%C%C",char1,char2,char3, etc);
it gets really bad garbled data
BUT if i use the command:
fprintf(SW_UART,"N/A,");
it prints that perfectly.
If i use longer delays the garbage data gets worse.
I am using max233 and this has never happened with the same code before. Only now when its in a pcb board and not on the breadboard I prototyped it to.
did i do something to my #use statement?
(software uart)
#use RS232(baud=2400,parity=N,xmit=PIN_B6,rcv=PIN_B7,bits=8,ERRORS,STREAM=SW_UART)
also: my bootloaded program times out first time (sends the garbage code)
but if I retry, it works 100% of the time and the code is correct |
Posted: Mon Mar 19, 2007 8:59 am |
'ERRORS', does nothing on a software UART.
You talk about 'delays'. If these are interrupt driven, then this is the problem. The software UART, requires nothing else to interrupt it's timings. It is possible to bodge round this, with code like:
void send_char_sw(int8 chr) {
disable_interrupts(GLOBAL);
fputc(chr,W_UART);
//Then use this with
printf(send_char_sw,"Test message");
Depending on how 'late' your compiler is, there may be the option for the #USE RS232, of 'DISABLE_INTS', which does the same thing.
These approaches, allow interrupts to be serviced between the characters being sent.
At a low rate like 2400bps, it is possible to have interrupt routines called, provided these are kept really short, and the frequency is not too high. However this needs _care_.
grasspuddle
Posted: Mon Mar 19, 2007 9:36 am |
ERRORS was added as a desperate last attempt
the 'delays' are the delay_ms() command inbetween printf commands
not putting them in causes the code to be 'mostly correct' I.E. I can still see some good data being sent, but using delay_ms(500) then it causes ALL data to be garbage except for the "N/A," text. |
