sokrates
| PIC to LCD - again |
Posted: Thu Mar 15, 2007 2:52 pm |
I am working on a senior design project that will use 18F452. Project will include A/D conversion at some point.
I will have relatively simple questions and I hope somebody could reply me
I am using CCS C 4.023 (our school has a licence) and I am just trying to send A/D data to an LCD.
I tried to use PIC Wizard as an aid, but I think it adds some unnecessary "disable" lines so I removed some of them.
My code is
| Code: | #include "F:\Program Files\PICC\Projects\LCD3\lcd3.h"
#include <stdio.h>
/*#define LCD_ENABLE_PIN PIN_B0
#define LCD_RS_PIN PIN_B1
#define LCD_RW_PIN PIN_B2
#include <lcd.c>
{ int value;
unsigned char result[]=" ";
set_tris_b(0); //set port b as output
setup_adc_ports(ALL_ANALOG);
set_adc_channel(0);
for(;;)
{ lcd_init();
value=Read_ADC();
sprintf(result,"%d",value);
lcd_putc(result);
delay_ms(250);
with the header
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#use delay(clock=10000000) |
Actually the header part does not mean anything at all to me!
This code actually compiles without any errors but whenever I load it to Proteus 6.0 18F452, the program (ISIS) crashes.
The connections are very basic too:
I am using Port B ( all 7 pins ) to drive the LCD and from Port A0, I am sending a sine wave.
( I didn't forget to uncomment the line that switches from Port B to Port D)
Apart from this, I could not figure out how the LCD is driven by the PIC.
I checked out some sample code but none of them actually specifies input/output directions for the ports.
Moreover, in the PIC wizard, the port specification part asks me the I/O connections but that doesn't correspond to anything in the code tab.
Is there something wrong with my compiler or is it just normal?
For the moment, that's all I wanted to know about
Thank you very much in advance
Posted: Thu Mar 15, 2007 3:02 pm |
This is not a Proteus board.
But, with regard to your C program, I see a few problems.
| Quote: | | unsigned char result[]=" "; |
This array can only hold a string that consists of one character
(plus the zero byte at the end, which acts as the string terminator).
Then down here in your code, you are writing up to 3 ASCII characters
to your array. It can only hold one. You strongly risk destroying
any variables that the compiler has allocated in the RAM addresses
just after your array.
| Quote: | | sprintf(result,"%d",value); |
You need to increase the size of the array.
Also you've got other things in there like enabling LVP mode.
I don't know what Proteus does with that, but with real hardware
you risk a lockup. Change it to NOLVP. |
mskala
Joined: 06 Mar 2007 Posts: 100 Location: Massachusetts, USA
Posted: Thu Mar 15, 2007 6:47 pm |
I've just done this recently. I was using ports D and E, but will work with any. From your pin definitions, you are using the Motorola M68-type format. If you need specs for this type of parallel interface, google it.
I was using 8 bits, but 4 bits is similar, you will need to use 2 cycles of the E bit rather than 1.
Here are the segments of code:
#define VFD_RW PIN_E0
#define VFD_E PIN_E1
#define VFD_RS PIN_E2
void vfd_w_inst(int8 value) // write instruction
output_low(VFD_RS);
output_low(VFD_RW);
output_high(VFD_E);
output_d(value);
output_low(VFD_E);
void vfd_w_data(int8 value) // write data
output_high(VFD_RS);
output_low(VFD_RW);
output_high(VFD_E);
output_d(value);
output_low(VFD_E);
void initdisp() // initialize display after power up
vfd_w_inst(0x3c); // function set, necessary first command
delay_us(2);
vfd_w_inst(0x0c); // display on, no cursor, no blink
delay_us(2);
vfd_w_inst(0x01); // clear display
delay_us(2);
vfd_w_inst(0x03); // cursor home
delay_us(2);
vfd_w_inst(0x06); // entry mode set
delay_us(2);
void displaynumber2(int8 num) // displays 8-bit number in decimal always 3 dig
int8 copy,a,b,c;
a=num/100;
copy=num-(a*100);
b=copy/10;
c=copy-(b*10);
vfd_w_data(a+48);
vfd_w_data(b+48);
vfd_w_data(c+48);
anywhere after initializing you can send characters as:
vfd_w_data('V');
vfd_w_data('a');
vfd_w_data('l');
vfd_w_data('u');
vfd_w_data('e');
vfd_w_data('=');
vfd_w_data(' ');
Good luck |
