Reading various SFRs at run time
kgn340
PostPosted: Wed Feb 14, 2007 2:02 pm     Reply with quote
Hi all,
I'm working with the PIC18F8722 and have developed a simple user interface.
To aid in debugging, I would like to be able to read various Special Function Registers (T3CON, ADCON0, T1CON, etc) at run time.
Is there some time of read that will allow me to index into the SFRs?
ie. SFR_READ ( 0xFCD ) would read T1CON.
Thanks,
kevin
PostPosted: Wed Feb 14, 2007 2:17 pm     Reply with quote
Use the CCS #byte directive to declare the address of the SFR register.
Look up the address in the PIC's data sheet, or use a pre-made SFR
declarations file:
http://www.ccsinfo.com/forum/viewtopic.php?t=14755
Then treat the declared register name as a normal variable.
Example:
#byte T1CON = 0xFCD
int8 value;
value = T1CON;
kgn340
PostPosted: Wed Feb 14, 2007 2:24 pm     Reply with quote
I guess I didn't make myself clear enough.
In my program I would like the ability to read *any* SFR register, not just hard coded ones.
if possible, it will help me debug a set of operating issues as they arise.
is this possible?
PostPosted: Wed Feb 14, 2007 2:29 pm     Reply with quote
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=23368
kgn340
PostPosted: Wed Feb 14, 2007 3:00 pm     Reply with quote
AWESOME!!!
that's what it was.
THANK YOU!!!
