_olaf_
| Problem with Output_low/high() |
Posted: Sun Feb 11, 2007 4:47 am |
I have a question about setting the output of portpins on a 16F873. If I use the following Code, everything is o.k.
| Code: | switch (x)
case 0: OUTPUT_A(0x00);
case 1: OUTPUT_A(0x03);
case 2: OUTPUT_A(0x05);
case 3: OUTPUT_A(0x01);
But if I use the output_low or *_high statement like I use it in the following code the pins don't have the behaviour what they should have.
switch (l_n)
case 0: output_low(Q_A2);
output_low(Q_B2);
output_low(Q_C2);
case 1: output_high(Q_B2);
output_low(Q_C2);
case 2: output_high(Q_A2);
output_low(Q_B2);
output_high(Q_C2);
case 3: output_high(Q_A2);
output_low(Q_B2);
output_low(Q_C2);
The two examplecode should not do the same, ist is only an example of the code which is working (OUTPUT_A() ) and the one (output_low/high() ) which does not work
Does anyone have an idea what the Problem is. Interrupts are all disabled. I have tried to bring an delay between the instruction but without succes. It is the same behaviour on PortA or PortB.
Regards Olaf |
Ttelmah Guest
Posted: Sun Feb 11, 2007 5:06 am |
What are the pin definitions being used in the output high/low instructions. Difficult for us to know what is happening without these...
However, the 'odds' are that this is the RMW problem.
On the PIC, when you set /clear an individual pin, the current status of the pins is read from the port, modified, and writen back to the port (hence read, modify, write - RMW). Now two things cause problems here. The first is if there is significant capacitance present, where if a pin is changed, it takes _time_ to reach the required voltage. However a delay added between each instruction nd the next, should solve this. The second though is loading. For instance, if a pin drives an LED directly, without a suitable current limit resistor, it may never reach the required output voltage, and will therefor always read incorrectly. The answer to this, is to design the circuit properly...
vsmguy
Posted: Sun Feb 11, 2007 7:44 am |
It would be great if the OP provided the schematic and the pin definition.
Would help us answer straight away. I have written almost the same code a while ago, and faced no problem.
Perhaps a simple voltage follower on the output pins might do the trick ? |
_olaf_
Posted: Sun Feb 11, 2007 8:23 am |
I think it is not a hardwareproblem. At the pin there is only a Low-Current LED (1,5mA with resistor), no capacitance is connected (I know the problem of this since my first controller PCB ). This should be low enough for the port. As I mentiond above, I tried to insert a delay with up to 200ms. This was the first thing I tried, because I had some timingproblems on another project before. But it is the same behaviour, the pins are not set.
The Pin definition is like
#define Q_A2 40 // PortA0
#define Q_B2 41 // PORTA1
#define Q_C2 42 // PORTA2
The Problem is, that there is a different behaviour on the same pins. If I make a short test with toggling the portpins it is different when using the OUTPUT_X or the output_low/high. This is what I don't understand. It should be the same. The pins should go high and low.
EDIT:
I have forgotten the Compilerversion
MPLAB V7.43
Compiler PCM 3.223 |
