how to output a 16bit value to two 8 bit ports
brood
PostPosted: Tue Jan 23, 2007 8:23 am     Reply with quote
Hi
I would like to know if its possible to output a 16bit value to two 8 bit ports and how to do it. The pic that I'm using is: pic16f917
My aim is to control 16 led's connected to port A and port B with a single hex value. I was successful with controlling port A with a single hex value.
here is my setup code with two code arrays:
#include <16F917>
#fuses INTRC_IO,NOPROTECT,NOWDT,PUT
#use delay(clock=8000000)
#use standard_io(a)
#use standard_io(b)
#use standard_io(c)
#use standard_io(d)
#case
const unsigned int A[10] = {0xFFF8, 0xFFFC, 0x0186, 0x0183, 0x0181, 0x0181, 0x0183, 0x0186, 0xFFFC, 0xFFF8}; //A
const unsigned int a[5] = {0x7C, 0x12, 0x11, 0x12, 0x7C}; //a
setup_lcd(LCD_DISABLED); // disables lcd display to access digital outputs
for (;;)
output_a(a[0]); // 1st line of a
SherpaDoug
PostPosted: Tue Jan 23, 2007 8:29 am     Reply with quote
How about using make8() to split the bytes, and dealing with each byte seperately?
brood
PostPosted: Tue Jan 23, 2007 9:01 am     Reply with quote
I think that might just do the trick
Thank you very much Wink
treitmey
PostPosted: Tue Jan 23, 2007 9:24 am     Reply with quote
you could also try fastio.
set the tris.
use a #byte to define where it is placed.
((or overlayed, how ever you want to think of it))
It uses the location and the next. ie: portA and port B
#use fast_io(A)
#use fast_io(B)
struct PINS
   int16 leds;
struct PINS my;
#byte my= 0x05   //note: no semicolin    0x05=A0 on a 16F877
my.leds=0xABCD;
I chopped apart my code... I hope it still works
Don't forget to set tris A and B it isn't shown in this code.
mrpicing
an other way
PostPosted: Sun Jan 28, 2007 11:10 am     Reply with quote
you can do it as below.
unsigned long port16;  //it will accupy two bytes. byte 5, byte 6
#byte port16=5  /* porta address. check porta adress form device data sheet*/
/* other code*/
port16= 0xffff;  //put ur data as this
/* other code*/
brood
PostPosted: Sun Jan 28, 2007 3:30 pm     Reply with quote
Thank you for all the replies it solved lots of problems that I had. Everything is up and running now. I used make8() in the end and passed two 8bit values to my output function.
Wink
