CCS Forum Index
CCS Forum Index
PICDEM 2 plus with new pinout for LCD
PostPosted: Wed Jan 17, 2007 11:59 am     Reply with quote
Just got in a new PICDEM2PLUS 2006 board, in which they have upgraded to a Rohs compliant LCD. In doing so it they have changed the pinout to the LCD using only PORTD as listed below. I am trying to modify the current LCD driver to work with this new LCD. The first step i took was changing the struct overlay as follows to meet the new board requirement.
DB4 = RD0
DB5 = RD1
DB6 = RD2
DB7 = RD3
RS = RD4
RW = RD5
E = RD6
struct lcd_pin_map {
           int     data : 4;//rd0-rd3
           BOOLEAN rs;      //rd4
           BOOLEAN rw;      //rd5
                BOOLEAN enable;  //rd6
                 BOOLEAN unused;  //rd7
         } lcd;
it looks like i can leave the tris pin map constants the same. After these changes the lcd will still not intialize. After looking at the asm lcd driver it looks like the setup up bytes are completely different from what they used to be. below is old and new
OLD LCD INIT:
LCDInit
   clrf   PORTA
   banksel   TRISA         ;configure control lines
   bcf   LCD_E_DIR
   bcf   LCD_RW_DIR
   bcf   LCD_RS_DIR
   movlw   b'00001110'
   banksel   ADCON1
   movwf   ADCON1
   movlw   0xff         ; Wait ~15ms @ 20 MHz
   banksel   COUNTER
   movwf   COUNTER
   movlw   0xFF
   banksel   delay
   movwf   delay
   call   DelayXCycles
   decfsz   COUNTER, F
   goto   $-3
   movlw   b'00110000'      ;#1 Send control sequence
   movwf   temp_wr
   bcf   STATUS,C
   call   LCDWriteNibble
   movlw   0xff         ;Wait ~4ms @ 20 MHz
   movwf   COUNTER
   movlw   0xFF
   movwf   delay
   call   DelayXCycles
   decfsz   COUNTER, F
   goto   $-3
   movlw   b'00110000'      ;#2 Send control sequence
   movwf   temp_wr
   bcf   STATUS,C
   call   LCDWriteNibble
   movlw   0xFF         ;Wait ~100us @ 20 MHz
   movwf   delay
   call   DelayXCycles
   movlw   b'0011000'      ;#3 Send control sequence
   movwf   temp_wr
   bcf   STATUS,C
   call   LCDWriteNibble
      ;test delay
   movwf   delay
   call   DelayXCycles
   movlw   b'00100000'      ;#4 set 4-bit
   movwf   temp_wr
   bcf   STATUS,C
   call   LCDWriteNibble
   call   LCDBusy         ;Busy?
   movlw   b'00101000'      ;#5   Function set
   movwf   temp_wr
   call   i_write
   movlw   b'00001101'      ;#6  Display = ON
   movwf   temp_wr
   call   i_write
   movlw   b'00000001'      ;#7   Display Clear
   movwf   temp_wr
   call   i_write
   movlw   b'00000110'      ;#8   Entry Mode
   movwf   temp_wr
   call   i_write
   movlw   b'10000000'      ;DDRAM addresss 0000
   movwf   temp_wr
   call   i_write
;   movlw   b'00000010'      ;return home
;   movwf   temp_wr
;   call   i_write
   return
   GLOBAL   LCDInit
NEW LCD INIT:
LCDInit
   banksel TRISD
   bcf      TRISD,7
   banksel   PORTD
   bsf      PORTD,7
   call   Delay30ms
   clrf   PORTA
   bcf   LCD_E_DIR
   bcf   LCD_RW_DIR
   bcf   LCD_RS_DIR
   movlw   b'00001110'
   banksel   ADCON1
   movwf   ADCON1
   banksel   COUNTER
   movwf   COUNTER
   movlw   0xFF
   banksel   delay
   movwf   delay
   call   DelayXCycles
   decfsz   COUNTER, F
   goto   $-3
;0x02------------------
;   movlw   b'00110000'      ;#1 Send control sequence
   movlw   b'00100000'      ;#1 Send control sequence
   movwf   temp_wr
   bcf   STATUS,C
   call   LCDWriteNibble
   movwf   COUNTER
   movlw   0xFF
   movwf   delay
   call   DelayXCycles
   decfsz   COUNTER, F
   goto   $-3
;28---2
;   movlw   b'00110000'      ;#2 Send control sequence
   movlw   b'00100000'      ;#2 Send control sequence
   movwf   temp_wr
   bcf   STATUS,C
   call   LCDWriteNibble
   movwf   delay
   call   DelayXCycles
;28--08
;   movlw   b'0011000'      ;#3 Send control sequence
   movlw   b'10000000'
   movwf   temp_wr
   bcf   STATUS,C
   call   LCDWriteNibble
      ;test delay
   movwf   delay
   call   DelayXCycles
;0C--0
;   movlw   b'00100000'      ;#4 set 4-bit
   movlw   b'00000000'      ;#4 set 4-bit
   movwf   temp_wr
   bcf   STATUS,C
   call   LCDWriteNibble
;0x0C
   movlw   b'11000000'      ;#4 set 4-bit
   movwf   temp_wr
   bcf   STATUS,C
   call   LCDWriteNibble
   call   Delay1ms
;0x01
   movwf   temp_wr
   bcf   STATUS,C
   call   LCDWriteNibble
;0x01
   movlw   b'00010000'      ;#4 set 4-bit
   movwf   temp_wr
   bcf   STATUS,C
   call   LCDWriteNibble
   call   LongDelay ;2ms
   call   LongDelay ;2ms
   call   LongDelay ;2ms
   call   LongDelay ;2ms
;0x02
   movwf   temp_wr
   bcf   STATUS,C
   call   LCDWriteNibble
;0x02
   movwf   temp_wr
   bcf   STATUS,C
   call   LCDWriteNibble
;   rcall   LCDBusy         ;Busy?
   call   LongDelay ;2ms
   call   LongDelay ;2ms
   call   LongDelay ;2ms
   call   LongDelay ;2ms
   call   LongDelay ;2ms
   call   LongDelay ;2ms
   call   LongDelay ;2ms
;   call   LCDBusy         ;Busy?
;   movlw   b'00101000'      ;#5   Function set
;   movwf   temp_wr
;   call   i_write
;   movlw   b'00001101'      ;#6  Display = ON
;   movwf   temp_wr
;   call   i_write
;   movlw   b'00000001'      ;#7   Display Clear
;   movwf   temp_wr
;   call   i_write
;   movlw   b'00000110'      ;#8   Entry Mode
;   movwf   temp_wr
;   call   i_write
;   movlw   b'10000000'      ;DDRAM addresss 0000
;   movwf   temp_wr
;   call   i_write
;   movwf   temp_wr
;   call   i_write
   movlw   0x4E
   movwf   temp_wr
   call   LCDBusy
   bsf   STATUS, C
   call   LCDWrite
   call   Delay1ms
   return
   GLOBAL   LCDInit
At this point I am not sure why there are many more configuration bytes being sent to the LCD, Is it a non-standara Hitachi LCD?? Has anyone implemented a working LCD driver for this LCD?? I guess its probably a an easy by changing and adding values to the LCD_INIT_STRING ?? Any input would be great!
PostPosted: Wed Jan 17, 2007 12:07 pm     Reply with quote
Try this driver in the Code Library. Change the pin list at the top of the
driver to fit the new PicDem2-Plus board. This will allow you to test if
the board is working.
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
PostPosted: Wed Jan 17, 2007 12:20 pm     Reply with quote
I used the flex friver updation to correct pins as followw, and get the same results, it appears as if it is not initializing (light bars on first line).
#define LCD_DB4   PIN_D0
#define LCD_DB5   PIN_D1
#define LCD_DB6   PIN_D2
#define LCD_DB7   PIN_D3
#define LCD_RS    PIN_D4
#define LCD_RW    PIN_D5
#define LCD_E     PIN_D6
By looking at the differences in the 2 assembly lcd init files, old to new, does it appear to you that the problem might be in the lcd init setup bytes??
PostPosted: Wed Jan 17, 2007 12:38 pm     Reply with quote
Download the manual for the new version of the board:
http://ww1.microchip.com/downloads/en/DeviceDoc/PICDEM_2_Plus_Users_Guide_51275c.pdf
It shows that they have added a power control pin for the LCD on pin D7
of the PIC. You have to set pin D7 to a logic high level to turn on the LCD.
To implement this, create a new constant called LCD_POWER and
put it with the other LCD #define statements at the start of the driver.
Then add a statement to set the power pin to a high level at the
beginning of the lcd_init() function. Example:
#define LCD_POWER PIN_D7
void lcd_init(void)
int8 i;
output_high(LCD_POWER);
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_RW);
output_low(LCD_E);
delay_ms(15);
Mark
PostPosted: Wed Jan 17, 2007 2:09 pm     Reply with quote
I like to do it like this:
struct lcd_pin_map
  BOOLEAN rs;      //rd4
  BOOLEAN rw;      //rd5
  BOOLEAN power;  //rd7
} lcd;
and access it like this:
lcd.power = TRUE;
You will also have to make sure the tris map has bit 7 as an output.
fvnktion
PostPosted: Wed Jan 17, 2007 3:16 pm     Reply with quote
Thanks much, that did the trick. Its been fun reading your guy's code and learning oodles from it (PCM and Mark). Here is the driver with modifications that works for the new PICDEM2 PLUS board (Rhos LCD)
Cheers and thanks again
////                             LCDD.C                                ////
////                 Driver for common LCD modules                     ////
////  lcd_init()   Must be called before any other function.           ////
////  lcd_putc(c)  Will display c on the next position of the LCD.     ////
////                     The following have special meaning:           ////
////                      \f  Clear display                            ////
////                      \n  Go to start of second line               ////
////                      \b  Move back one position                   ////
////  lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)    ////
////  lcd_getc(x,y)   Returns character at position x,y on LCD         ////
////        (C) Copyright 1996,2003 Custom Computer Services           ////
//// This source code may only be used by licensed users of the CCS C  ////
//// compiler.  This source code may only be distributed to other      ////
//// licensed users of the CCS C compiler.  No other use, reproduction ////
//// or distribution is permitted without written permission.          ////
//// Derivative programs created using this software in object code    ////
//// form are not restricted in any way.                               ////
// Un-comment the following define to use port B
// #define use_portb_lcd TRUE
           BOOLEAN rs;      //rd4
           BOOLEAN rw;      //rd5
         } lcd;
#if defined(__PCH__)
#if defined use_portb_lcd
   #byte lcd = 0xF81                   // This puts the entire structure
#else
   #byte lcd = 0xF83                   // This puts the entire structure
#else
   #byte lcd = 6                  // on to port B (at address 6)
#else
   #byte lcd = 8                 // on to port D (at address 8)
   #define set_tris_lcd(x) set_tris_b(x)
#else
   #define set_tris_lcd(x) set_tris_d(x)
#define lcd_power PIN_D7
#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40    // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                             // These bytes need to be sent to the LCD
                             // to start it up.
                             // The following are used for setting
                             // the I/O port direction register.
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0};
struct lcd_pin_map const LCD_READ = {15,0,0,0,0};
//reads data pins to see if busy, high data bit(rd3) high if busy, poll rd3
BYTE lcd_read_byte() {
      BYTE low=0,high=0;
      set_tris_lcd(LCD_READ);
      lcd.rw = 1;
      delay_cycles(1);
      lcd.enable = 1;
      delay_cycles(1);
      high = lcd.data;
      lcd.enable = 0;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(1);
      low = lcd.data;
      lcd.enable = 0;
      set_tris_lcd(LCD_WRITE);
       return( (high<<4>> 4);
      lcd_send_nibble(n & 0xf);
void lcd_init() {
    BYTE i;
      lcd.power = TRUE;
    lcd.rs = 0;
    lcd.rw = 0;
    lcd.enable = 0;
    delay_ms(15);
    for(i=1;i<=3;++i) {
       lcd_send_nibble(3);
       delay_ms(5);
    lcd_send_nibble(2);
    for(i=0;i<=3;++i)
       lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
   BYTE address;
   if(y!=1)
     address=lcd_line_two;
     address=0;
   address+=x-1;
   lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
   switch (c) {
     case '\f'   : lcd_send_byte(0,1);
                   delay_ms(2);
     case '\n'   : lcd_gotoxy(1,2);        break;
     case '\b'   : lcd_send_byte(0,0x10);  break;
     default     : lcd_send_byte(1,c);     break;
char lcd_getc( BYTE x, BYTE y) {
   char value;
    lcd_gotoxy(x,y);
    while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
    lcd.rs=1;
    value = lcd_read_byte();
    lcd.rs=0;
    return(value);
mindstorm88
PostPosted: Tue Feb 06, 2007 7:07 pm     Reply with quote
Are you sure ?? few errors and missing stuff!!!! , Can you repost it ???
PostPosted: Tue Feb 06, 2007 7:57 pm     Reply with quote
He didn't disable HTML when he posted it. That's the reason.
PostPosted: Thu Feb 08, 2007 11:51 am     Reply with quote
Sorry about that, here is the code with html disabled at posting. By the way my version LCD is OCULAR OM16214.
////                             LCDD.C                                ////
           BOOLEAN rs;      //rd4
           BOOLEAN rw;      //rd5
         } lcd;
#else
#else
#else
#else
                             // to start it up.
      BYTE low=0,high=0;
      lcd.rw = 1;
      delay_cycles(1);
      lcd.enable = 1;
      delay_cycles(1);
      high = lcd.data;
      lcd.enable = 0;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(1);
      low = lcd.data;
      lcd.enable = 0;
     return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
      lcd.data = n;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(2);
      lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n ) {
      lcd.rs = 0;
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd.rs = address;
      delay_cycles(1);
      lcd.rw = 0;
      delay_cycles(1);
      lcd.enable = 0;
      lcd_send_nibble(n >> 4);
void lcd_init() {
    BYTE i;
   lcd.power = TRUE;
    lcd.rs = 0;
    lcd.rw = 0;
    lcd.enable = 0;
    delay_ms(15);
    for(i=1;i<=3;++i) {
      lcd_send_nibble(3);
      delay_ms(5);
    lcd_send_nibble(2);
    for(i=0;i<=3;++i)
   BYTE address;
   if(y!=1)
     address=0;
   address+=x-1;
   switch (c) {
                   delay_ms(2);
   char value;
    lcd_gotoxy(x,y);
    lcd.rs=1;
    lcd.rs=0;
    return(value);
You can post new topics in this forum
You can reply to topics in this forum
