How to copy arrays quickly ??
arunb
PostPosted: Wed Jan 17, 2007 11:00 am     Reply with quote
How do I quickly copy arrays in PCM 3.228 ??
I use a for loop to run through the arrays, but are there any faster methods than this ???
thanks
arunb
PostPosted: Wed Jan 17, 2007 11:23 am     Reply with quote
Use memcpy(). It's in the CCS manual.
PostPosted: Wed Jan 17, 2007 5:49 pm     Reply with quote
Memcpy() is indeed a better solution than a for-loop. Something not mentioned in the manual is that the CCS compiler is using an internal optimized memcpy() routine, not the memcpy routine you will find in one of the standard include files. The internal routine is so fast because it uses the index register which has an auto increment feature.
For PIC18 only:
One limitation of the CCS generated code is that it uses only 1 of the 3 available index registers. There are some situations where you have to copy data from one array to another but memcpy is not flexible enough. In these situations you can achieve higher speeds by writing your own (assembler) code using two index registers.
treitmey
PostPosted: Thu Jan 18, 2007 10:01 am     Reply with quote
Any chance either of you fellows could post that type of assembly code.
I know this isn't a forum for assembly code, but now you have my interest peeked. I would love to see how this is done.
You could use a #asm #endasm and claim it to be ccs related. : )
Are both of you also on the Microchip forum??
I could ask for it there.
libor
PostPosted: Thu Jan 18, 2007 12:53 pm     Reply with quote
#byte FSR0H = 0xFEA
#byte FSR0L = 0xFE9
#byte FSR1H = 0xFE2
#byte FSR1L = 0xFE1
#byte POSTINC0 = 0xFEE
#byte POSTINC1 = 0xFE6
void memcpy_asm(int8 *src, int8 *dest, int8 n)  {   // n number of bytes to copy
  #asm
  movff &dest+1, FSR1H
  movff dest, FSR1L
  movff &src+1, FSR0H
  movff src, FSR0L
  loop:
  movff POSTINC0, POSTINC1
  decfsz n
  goto loop
  #endasm
...not tested.
PS. Though I don't know how safe it is to use the FSR0-2 registers without the compiler being aware of their corrupted contents. (you might want to save/restore them, or as mentioned above knowing the compiler uses FSR0, using FSR1-2 would be safer..)
treitmey
PostPosted: Thu Jan 18, 2007 2:03 pm     Reply with quote
thanks, I'll test it out.
PostPosted: Thu Jan 18, 2007 8:20 pm     Reply with quote
Hi Ttreitmey,
No, I'm not on the Microchip forum. This forum is taking all my spare time. Wink
Does someone know if the LFSR assembly instruction is supported by CCS? I only get compiler errors.
treitmey
PostPosted: Thu Jan 18, 2007 9:00 pm     Reply with quote
Funny, I thought they all were. Surprised
How can you find out which are/are not?
PostPosted: Thu Jan 18, 2007 9:15 pm     Reply with quote
This compiles OK with vs. 3.249:
#include <18F452.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#define FSR0  0xFE9
#asm
LFSR  FSR0, 0x0100
#endasm
