rwskinner
| Baud Rate Issues |
Posted: Mon Jan 15, 2007 5:02 pm |
Newbie with CCS so bare with me....
I'm running a 18F2580 at 20 Mhz. I have two jumpers to set the baud rate via A0 & A1. I'm using
My Program initially sets the bausd rate via Use 232 like this....
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,UART1,errors,stream=COMM_1,enable=Pin_b1)
Then in my Main, before my loop I read the jumper settings...
switch( input_a() & 3 )
case 0 : set_uart_speed(9600,COMM_1); break;
case 1 : set_uart_speed(19200,COMM_1); break;
case 2 : set_uart_speed(38400,COMM_1); break;
case 3 : set_uart_speed(57600,COMM_1); break;
Everything works for 9600 to 38400 but when I try to set it at 57600 I end up with 9600 again.
Do I need to add the BRGH1OK in the use RS232 parameters?
What am I doing wrong?
In PBPRO, is simply set the registers directly
RCSTA = $90 ' Enable serial port & continuous receive
TXSTA = $24 ' Enable transmit, BRGH = 1
SPBRG = 10 ' 115200 Baud @ -1.36% |
rwskinner
Posted: Mon Jan 15, 2007 5:14 pm |
Okay, this is weird, but if I set my initial use RS232 to 57,600 then use set_uart_speed afterwards it works at all baud rates 9600 to 57600.
Why is that? Should I use the complete Use RS232 statement instead of just set_uart_speed?
Richard |
Posted: Tue Jan 16, 2007 5:54 am |
BRGH10K, won't help. This is a 'fix' for a fault on some chips, with using the BRGH register bit.
The problem though is tied to this register. The 'set_uart_speed' function, writes a suitable value into the basic baud rate generator register. The problem is that for 'fast' rates, the main setup function, knows to switch to using the higher rate setting, on the BRGH bit, but the set_uart_speed function, does not know to change this bit. By selecting 56K in the original setup, you force this bit to be set.
Now, some time ago on this forum, I think PCM Programmer posted a 'replacement' version of the set_uart_speed function, for older compiler versions that did not have this code. It might be worth finding this, and seeing if his version correctly handles this bit. Otherwise, the answer is to just change this one bit yourself, in the switch statement. Define the bit using #bit, and set it on/off as needed.
rwskinner
Posted: Tue Jan 16, 2007 6:18 am |
Thanks for the reply. I kind of figured that was what was happening and when USE RS232 was used at 57600 the routines knew to use the high speed baud generator but not on set uart speed.
I will set it directly as you suggested. Leaving BRGH = 1 should be fine for all the speeds I'm running so I should just be to set that only once right above my switch statement. |
