JDM PIC programmer problem
handsprince
PostPosted: Sat Nov 25, 2006 8:38 pm     Reply with quote
i have a JDM PIC programmer, it can works well with PC but cannot work with my laptop....anyone can suggest me how to solve this problem....thanks Smile
PostPosted: Sat Nov 25, 2006 10:37 pm     Reply with quote
Are you by chance using a USB to serial converter? If so there have numerous comments here and other places about incompatibilities. I use the Belkin that works pretty well.
Even if you don't use a converter, one major issue may be the fact that the JDM programmer is powered from the serial port and laptops many times don't have as high a voltage for the serial port as a PC.
See this link for comments about this issue and more info:
http://www.k9spud.com/jdm/
Since there is no provision for an external supply you may be out of luck. If this is the case JDM does offer you your money back..... Sad
tsupuntu
PULL UP V+
PostPosted: Mon Nov 27, 2006 11:05 am     Reply with quote
You should pull up V+12volt R 4.7k on MCLR pin then pull up 5 volt R4.7k with clk and data pin
