Aycan
| trouble with PWM |
Posted: Sun Nov 19, 2006 3:06 pm |
Hi Everybody...
I try to motor speed control by pwm in my centrifuge prototype.Basic functions are Read keypad, Refresh 7 segment display, Read Motor Rpm, Drive motor by PWM, Count down work time. Centrifuge work fine many times. But sometimes PWM doesn't clear at the end of work time .Does anybody can explain what's wrong in my codes.
My best regards.
Aycan
[/code]
// MEDICAL CENTRIFUGE SPEED CONTROL //
#include <16F876>
#use DELAY(CLOCK=20000000)
#fuses HS,NOWDT,PUT,BROWNOUT,PROTECT,NOLVP
#include <DispDrv>
#include <KBD3X2>
// INIT TIMER0 FOR INTERRUPT
void Timer_Init(){
// INIT TIMER1 For CAPTURE
void Capture_Init(){
// INIT TIMER 2 FOR PWM MODE
void Pwm_Init(){
SETUP_CCP2(CCP_PWM); //select pwm mode
SETUP_TIMER_2(T2_DIV_BY_16, 250 , 1); //load period value
SET_PWM2_DUTY(0); //load duty cycle value
// ISR Timer1 for low rpm
#Int_Timer1
void Timer1_Isr() {
// ISR (CAPTURE) FOR MOTOR RPM MEASUREMENT
#int_ccp1
void Capture_Isr() {
// ISR FOR TIME INTERVAL
#INT_RTCC
void CLOCK_ISR(){
SET_RTCC(60);
if(++Counter>=200){
Counter=0; RpmAvrg=1;
if(Start){
if(Second==0){
if(Minute==0) {
EOT=1;
else {
Second=59; --Minute;
else {
--Second;
DispUpdate(); // refresh seven segment display
// MAIN ROUTINE
void main(){
Timer_Init();
Pwm_Init();
Capture_Init();
ENABLE_INTERRUPTS(INT_RTCC);
ENABLE_INTERRUPTS(INT_CCP1);
ENABLE_INTERRUPTS(INT_TIMER1);
ENABLE_INTERRUPTS(GLOBAL);
while (1){
KbChr=KBD_GETC();
if(KbChr!=0) Menu();
if(Eot){ // when count down timer up
Set_Pwm2_Duty(0); // Clear Pwm, motor stop
Eot=0;
if(Start){ // when motor running
calculate rpm using captured time value
calculate motor drive pwm value
Posted: Sun Nov 19, 2006 3:16 pm |
Without seeing more of the code, hard to be sure, but I don't see 'start' being set to false or 0 anywhere. As such, when 'eot' changes, the PWM duty will be set to zero, anf then eot cleared. Because 'start' is still true, the pwm cycle will then be output again to keep the motor running.
Aycan
Posted: Thu Nov 23, 2006 3:17 am |
Dear Ttelmah
I found my mistake and fixed problem. Thanks for interest.
My best regards. |
