dorsiareservations
| Communication Between 2 Embedded Ethernet Boards |
Posted: Thu Nov 16, 2006 11:38 am |
I am currently using the latest version of the CCS Compiler and the Ported microchip stack, along with 2 embedded ethernet boards. My goal is to simply communicate between the two boards using two UDP Sockets on each board. My program is simple, it simply sends a packet, does a stacktask(), recieves a packet, does a stacktask(), and repeats. However, the two boards will not recieve packets from one another.
Here is what is happening:
1)I can send packets back and forth from a laptop to an embedded board no problem what so ever.
2)I can view the packets being sent from each ethernet board to the other through etherreal. All the Information looks correct, MAC Addresses, ports, IP's, etc.
3)I have a timer counting how many packets per second are being transmitted, which is near 1000. If I plug in another embedded ethernet card (The one that I am trying to communicate with), the packets drop to 500 on each board. This makes sense, because it has to process the recieving packets and can not transmit as many.
4)If I unplug the board, or put in a different MAC address or IP address, the packets transmitted stay at 1000/second. This makes sense, because the board will not have to process incoming packets.
So Judging from the the fact that the packet rate drops when I transmit to the right mac and IP, I know the board is recieving packets. In the code I have narrowed it down, and I have found that it never enters the "UDPisGetReady(Socket)" loop. Can anyone offer a suggestion, or do they have working code for such a scenario? It would be much appreciated.
#define STACK_USE_ICMP 0
#define STACK_USE_ARP 0
#define STACK_USE_UDP 1
#define LOCAL_ID 7
#define REMOTE_ID 11
#define MAX_SOCKETS 6
#define MAX_UDP_SOCKETS 4
#include "ccstcpip.h"
#if STACK_USE_CCS_PICENS
#include "tcpip/mlcd.c"
#else
#include "tcpip/dlcd.c"
#endif
#define UDP_SOURCE_PORT 1024
#define UDP_DESTINATION_PORT 1025
#define UDP_NUM_LISTEN_SOCKETS 2
UDP_SOCKET last_rx_socket=INVALID_UDP_SOCKET;
unsigned int16 totalcount=0;
unsigned int16 totalcount2=0;
void UDPRxTask(void)
static UDP_SOCKET socket=INVALID_UDP_SOCKET;
int8 i;
char c;
if (socket==INVALID_UDP_SOCKET)
socket=UDPOpen(UDP_SOURCE_PORT,NULL,INVALID_UDP_SOCKET);
// UDPClose(socket);
printf("\r\nUDP Rcv SOCKET Jacked Up");
printf("\r\nUDP SOCKET %U OPEN FOR LISTENING", socket);
if (UDPIsGetReady(socket))
totalcount++;
output_toggle(PIN_B5);
while(UDPGet(&c))
i=c;
UDPDiscard();
void UDPTxTask(void) {
NODE_INFO remote_info;
static int8 button;
static int8 tx_socket=INVALID_UDP_SOCKET;
// remote node mac and IP
remote_info.IPAddr.v[0]=192;
remote_info.IPAddr.v[1]=168;
remote_info.IPAddr.v[2]=100;
remote_info.IPAddr.v[3]=0x12;
remote_info.MACAddr.v[0]=0x01;
remote_info.MACAddr.v[1]=0x02;
remote_info.MACAddr.v[2]=0x03;
remote_info.MACAddr.v[3]=0x04;
remote_info.MACAddr.v[4]=0x05;
remote_info.MACAddr.v[5]=0x12;
if (tx_socket==INVALID_UDP_SOCKET)
tx_socket=UDPOpen(1010, &remote_info, UDP_DESTINATION_PORT);
printf("\r\nUDP SOCKET %U OPEN FOR sending", tx_socket);
if (UDPIsPutReady(tx_socket))
printf(UDPPut, "\r\nBUTTON%U ",++button);
UDPFlush();
// UDPClose(tx_socket);
output_toggle(PIN_A5);
totalcount2++;
int16 time_ms=0;
#int_TIMER2
TIMER2_isr()
time_ms++;
void main(void) {
int temp=0;
printf("\n\rStarting");
setup_timer_2(T2_DIV_BY_16,195,16);// Timer2 interrupts every 5 ms
MACAddrInit();
IPAddrInit();
init_user_io();
printf(lcd_putc,"\fCCS UDP TUTORIAL\nLISTENING");
StackInit();
StackTask();
UDPRxTask();
StackTask();
UDPTxTask();
if (time_ms>100)
printf(lcd_putc,"\fTot Rcvd=%lu",totalcount);
printf(lcd_putc,"\nTot Txed=%lu",totalcount2);
output_toggle(PIN_B4);
totalcount=0;
totalcount2=0;
time_ms=0;
Obviously, the ports, MAC addresses and IP's are reversed in the code that goes on the other board. Please help Im at my wits end. Im ver close to moving to realtek and hi-tecc. |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Thu Nov 16, 2006 1:03 pm |
A few things...
a.) UDP and UDPOpen() are very poorly documented in Microchip's Application Note. In fact, you take anything said with that Application Note with a grain of salt as it was written 4 years ago (and hasn't been updated as the stack has gotten updated) and contains many errors. Therefore you really do need to read the stack source code to get an idea of how it really works.
b.) The port you are using in the tx task is a different port being used in the rx task.
c.) You are not correctly using StackTask(). There should only be one StackTask() in your main loop. I thought that if there was data in the RX buffer and StackTask() was called it would clear the RX buffer to make space for the next packet, but it seems like the later versions of the stack don't do that anymore so I'm not sure if that's a valid comment. _________________ I came, I saw, I compiled. |
dorsiareservations
Posted: Thu Nov 16, 2006 2:16 pm |
Darren,
In regards to the the UDPOpen function, what specifically am I doing wrong then? This is a modified version of the CCS example 12a(I think). The one that communicates with the computer.
In regards to the ports being different, I am aware of that. The code for the other ethernet board is the same thing, with the mac addresses, ips, and ports switched. Hence, the recieving port on board A is the destination port on board B, etc.
My prior code to this had the stacktask() used only once in the main loop. The results were exactly the same. |
dorsiareservations
Posted: Thu Nov 16, 2006 2:23 pm |
| On another note, it would be nice to see this stuff built into the compiler, perhaps in the project wizard? Hint Hint. |
dorsiareservations
Posted: Thu Nov 16, 2006 2:36 pm |
here are 2 packets captured from etherreal. 1 from each embedded ethernet board.
No. Time Source Destination Protocol Info
1 0.000000 192.168.100.7 192.168.100.18 UDP Source port: 1010 Destination port: 1018
Frame 1 (60 bytes on wire, 60 bytes captured)
Arrival Time: Nov 17, 2006 00:18:06.465293000
Time delta from previous packet: 0.000000000 seconds
Time since reference or first frame: 0.000000000 seconds
Frame Number: 1
Packet Length: 60 bytes
Capture Length: 60 bytes
Protocols in frame: eth:ip:udp:data
Ethernet II, Src: 01:02:03:04:05:07, Dst: 01:02:03:04:05:12
Destination: 01:02:03:04:05:12 (01:02:03:04:05:12)
Source: 01:02:03:04:05:07 (01:02:03:04:05:07)
Type: IP (0x0800)
Trailer: 00000000000000
Internet Protocol, Src Addr: 192.168.100.7 (192.168.100.7), Dst Addr: 192.168.100.18 (192.168.100.18)
Version: 4
Header length: 20 bytes
Differentiated Services Field: 0x00 (DSCP 0x00: Default; ECN: 0x00)
0000 00.. = Differentiated Services Codepoint: Default (0x00)
.... ..0. = ECN-Capable Transport (ECT): 0
.... ...0 = ECN-CE: 0
Total Length: 39
Identification: 0x3a04 (14852)
Flags: 0x00
0... = Reserved bit: Not set
.0.. = Don't fragment: Not set
..0. = More fragments: Not set
Fragment offset: 0
Time to live: 100
Protocol: UDP (0x11)
Header checksum: 0xd357 (correct)
Source: 192.168.100.7 (192.168.100.7)
Destination: 192.168.100.18 (192.168.100.18)
User Datagram Protocol, Src Port: 1010 (1010), Dst Port: 1018 (1018)
Source port: 1010 (1010)
Destination port: 1018 (1018)
Length: 19
Checksum: 0x0000 (none)
Data (11 bytes)
0000 01 02 03 04 05 12 01 02 03 04 05 07 08 00 45 00 ..............E.
0010 00 27 3a 04 00 00 64 11 d3 57 c0 a8 64 07 c0 a8 .':...d..W..d...
0020 64 12 03 f2 03 fa 00 13 00 00 0d 0a 42 55 54 54 d...........BUTT
0030 4f 4e 34 20 20 00 00 00 00 00 00 00 ON4 .......
2 0.000026 192.168.100.18 192.168.100.7 UDP Source port: 1010 Destination port: 1007
Frame 2 (60 bytes on wire, 60 bytes captured)
Arrival Time: Nov 17, 2006 00:18:06.465319000
Time delta from previous packet: 0.000026000 seconds
Time since reference or first frame: 0.000026000 seconds
Frame Number: 2
Ethernet II, Src: 01:02:03:04:05:12, Dst: 01:02:03:04:05:07
Destination: 01:02:03:04:05:07 (01:02:03:04:05:07)
Source: 01:02:03:04:05:12 (01:02:03:04:05:12)
Type: IP (0x0800)
Trailer: 0000000000
Internet Protocol, Src Addr: 192.168.100.18 (192.168.100.18), Dst Addr: 192.168.100.7 (192.168.100.7)
Version: 4
Total Length: 41
Identification: 0x2dc7 (11719)
Flags: 0x00
Fragment offset: 0
Time to live: 100
Header checksum: 0xdf92 (correct)
Source: 192.168.100.18 (192.168.100.18)
Destination: 192.168.100.7 (192.168.100.7)
User Datagram Protocol, Src Port: 1010 (1010), Dst Port: 1007 (1007)
Destination port: 1007 (1007)
Length: 21
Data (13 bytes)
0000 01 02 03 04 05 07 01 02 03 04 05 12 08 00 45 00 ..............E.
0010 00 29 2d c7 00 00 64 11 df 92 c0 a8 64 12 c0 a8 .)-...d.....d...
0020 64 07 03 f2 03 ef 00 15 00 00 0d 0a 42 55 54 54 d...........BUTT
0030 4f 4e 31 39 39 20 20 00 00 00 00 00 ON199 .....
Darren Rook
Posted: Thu Nov 16, 2006 3:05 pm |
Your UDPOpen() in the RX task is listening to UDP_SOURCE_PORT. Your UDPOpen() in the TX task is transmitting to UDP_DESTINATION_PORT. Those ports don't match, that's why your RX task doesn't receive anything. _________________ I came, I saw, I compiled. |
dorsiareservations
Posted: Fri Nov 17, 2006 7:38 am |
How do they not match? Am I missing something? Can you be a little more in depth in your explination because I thought I had this worked out. Obviously I am missing something. You are aware that there are 2 different boards, right? Here is the socket/port setup.
Board A:
Socket 1:(transmit socket)
Destination Port: 1018
Source Port: 1010(doesnt matter really)
Socket 2:(recieve Socket)
Source Port: 1007
Destination port: NULL
Board B:
Destination Port: 1007
Source Port: 1018
Is that not right? Board A has to listen on the port that Board B is sending to, and vice versa? |
dorsiareservations
Posted: Fri Nov 17, 2006 9:28 am |
| Disregard the port 1024 and 1025 in the first post. I changed the ports for clarity between posts....My mistake. The info from the etherreal dump is correct. |
Darren Rook
Posted: Mon Nov 20, 2006 9:17 am |
BTW your 'remote_info' isn't static, it's possible the values got corrupted.
Edit: Never mind, that's fine. _________________ I came, I saw, I compiled. |
dorsiareservations
Posted: Wed Nov 22, 2006 11:38 am |
I did some further research, and captured a Packet that the computer sends to the microcontroller board. (The ports are different again, but they are correct....)
Once again, this is an embedded baord and a computer sending and recieving packets simultaneously to each other through a switch. This is working fine. The packet that the microcontroller sends to the computer is virtual the same as the ones show above with a different MAC and IP and port, of course.
The ONLY major differences I found were the flags, and the checksum. The checksum is not zero, and the flag has the "dont fragment" flag set. Here is the packet.
Any more ideas would be greatly appreciated.
10358 17.259944 192.168.100.11 192.168.100.7 UDP Source port: 32768 Destination port: 1024
Frame 10358 (48 bytes on wire, 48 bytes captured)
Arrival Time: Nov 22, 2006 00:21:11.651287000
Time delta from previous packet: 0.000344000 seconds
Time since reference or first frame: 17.259944000 seconds
Frame Number: 10358
Packet Length: 48 bytes
Capture Length: 48 bytes
Ethernet II, Src: 00:0b:97:27:b5:ba, Dst: 01:02:03:04:05:07
Source: 00:0b:97:27:b5:ba (00:0b:97:27:b5:ba)
Type: IP (0x0800)
Internet Protocol, Src Addr: 192.168.100.11 (192.168.100.11), Dst Addr: 192.168.100.7 (192.168.100.7)
Version: 4
Total Length: 34
Identification: 0x0003 (3)
Flags: 0x04 (Don't Fragment)
.1.. = Don't fragment: Set
Fragment offset: 0
Time to live: 64
Header checksum: 0xf164 (correct)
Source: 192.168.100.11 (192.168.100.11)
User Datagram Protocol, Src Port: 32768 (32768), Dst Port: 1024 (1024)
Source port: 32768 (32768)
Destination port: 1024 (1024)
Length: 14
Checksum: 0x4983 (incorrect, should be 0x2a60)
Data (6 bytes)
0000 01 02 03 04 05 07 00 0b 97 27 b5 ba 08 00 45 00 .........'....E.
0010 00 22 00 03 40 00 40 11 f1 64 c0 a8 64 0b c0 a8 ."..@.@..d..d...
0020 64 07 80 00 04 00 00 0e 49 83 74 65 73 74 20 34 d.......I.test 4
