is it possible to use two ICD-U at the same time?
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
bcs99
PostPosted: Mon Oct 30, 2006 11:48 am     Reply with quote
I'm trying to get two pics to work together and I can only debug with one at a time. Is it possible to debug on two ICD-U at the same time?
Neutone
PostPosted: Mon Oct 30, 2006 12:02 pm     Reply with quote
I would use a second PC if I really had to debug from both ends at the same time.
I suggest you put a scope on the communication link between the two and approach it from that angle. Make sure the master is sending the right request and then check that the slave is sending the correct reply.
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
