Neckruin
| Big Switch!! |
Posted: Mon Oct 23, 2006 4:45 am |
I need to use a "switch" structure in which I'll have more than 30 different cases...
Is it recommended doing it as a "big switch-case"??
Any other option??
Thanks,
Juanma (the "big asker") :P |
Posted: Mon Oct 23, 2006 6:37 am |
No reason not to.
There are two different 'versions' of code generated by the switch statement though. If you use a normal 'switch', _with a 'default' statement present_, the code generated is exactly the same as if you used a whole tree of 'if' tests. If instead, you omit the 'default', the compiler will generate a much faster (for the latter tests), and more compact for dealing with a lot of tests, 'jump table'.
So it is more efficient, to have:
if (val>30) {
'your default code here'
else {
switch (val) {
case 0:
case 1:
case 29:
case 30:
//using all the cases 0..30 for the example given
