4 x Serial EEPROM 24AA1025 512 Kbytes direct access driver.
Redpic
PostPosted: Sun Oct 15, 2006 10:32 am     Reply with quote
This work is based in two previous works:
The EX_EXTEE.C from CCS C examples directory and
a post in this same Code Library section Driver Microchip 24AA512 512k I2C EEPROM by UFAnders
This driver is capable for addresing from 0x0000 to 0x7FFFF, 0x8000 positions = 512 Kbytes.
Driver:
// 4 x EEPROM 24AA1025 Driver with absolute memory addressing
#define EEDEBUG
// device hardware address
int8 const deviceAddress1 = 0b00000011; // #3
int8 const deviceAddress2 = 0b00000010; // #2
int8 const deviceAddress3 = 0b00000001; // #1
int8 const deviceAddress4 = 0b00000000; // #0
// baseAddress = 8 bits which mean ...
// Fixed (4 bits)            -> 1010
// EE internal Block (1 bit) -> 0 for 0000/FFFF, 1 for 10000/1FFFF
// Dev Hard Address (2 bits) -> 00 or 01 or 10 or 11
// R/W (1 bit)               -> 0 -> Write / 1 -> Read
int8 const baseAddress24AA1025 = 0b10100000;
// Aux Functions //////////////////////////////////////////////////////////////
int1  menRelative2BankSelect(int32 memRelativeAddress){
   int1 returnBit=0;
   if(memRelativeAddress>(int32) 0xffff) returnBit = 1;
   return returnBit;
int32 memAbsoluteAddress2menRelativeAddress(int8 deviceOrder, int32 memAddress){
   int32 returnInt32 = 0;
   switch(deviceOrder){
      case 1: returnInt32 = memAddress;
      case 2: returnInt32 = memAddress - 0x20000;
      case 3: returnInt32 = memAddress - 0x40000;
      case 4: returnInt32 = memAddress - 0x60000;
   return returnInt32;
int8 memAbsoluteAddress2deviceOrder(int32 memAddress){
   int8  returnByte=0;
   if((memAddress>0x05ffff) && (memAddress < 0x080000)) returnByte=4;
   if((memAddress>0x03ffff) && (memAddress < 0x060000)) returnByte=3;
   if((memAddress>0x01ffff) && (memAddress < 0x040000)) returnByte=2;
   if((memAddress< 0x020000)) returnByte=1;
   return returnByte;
int8 memAbsoluteAddress2deviceAddress(int32 memAddress){
   int8  deviceOrder=0, returnByte=0;
   deviceOrder = memAbsoluteAddress2deviceOrder(memAddress);
      case 0: returnByte = 0xff;
      case 1: returnByte = deviceAddress1;
      case 2: returnByte = deviceAddress2;
      case 3: returnByte = deviceAddress3;
      case 4: returnByte = deviceAddress4;
   return returnByte;
// Main Functions /////////////////////////////////////////////////////////////
void writeByte24AA1025(int32 memAddress, int8 data){
   int8  baseAddress;
   int8  deviceAddress;
   int8  deviceOrder=0;
   int32 memRelativeAddress;
   int8  bank=0;
   deviceAddress      = memAbsoluteAddress2deviceAddress(memAddress);
   memRelativeAddress = memAbsoluteAddress2menRelativeAddress(deviceOrder, memAddress);
   bank               = menRelative2BankSelect(memRelativeAddress);
   baseAddress        = baseAddress24AA1025 + (bank<<3)  + (deviceAddress<<1);
#ifdef EEDEBUG
   printf("\r\n\nAbsolute Address: %LX Relative Address: %Lx Device: %u Bank: %u\r\n",memAddress,memRelativeAddress,deviceOrder,bank);
   i2c_start();
   i2c_write(baseAddress);
   i2c_write(memRelativeAddress>>8);
   i2c_write(memRelativeAddress);
   i2c_write(data);
   i2c_stop();
   delay_ms(5);
int8 readByte24AA1025(int32 memAddress){
   int8  returnByte=0;
   int8  baseAddress;
   int8  deviceAddress;
   int8  deviceOrder=0;
   int8  bank=0;
#ifdef EEDEBUG
   i2c_start();
   i2c_start();
   i2c_write(baseAddress|1);
   returnByte = i2c_read(0);
   i2c_stop();
   return returnByte;
Adapted from example code EX_EXTEE.C, my own EEPROM_24AA1025x4.C:
// EEPROM_24AA1025x4.C
// based on EX_EXTEE.C example by CCS
// and "Microchip 24AA512 512k I2C EEPROM driver" by UFAnders
// in http://www.ccsinfo.com/forum/
// by RedPic from http://picmania.garcia-cuervo.com
// October 2006
#include <18F4550.h>
#use delay(clock=20000000)
#use i2c(master, sda=PIN_B0, scl=PIN_B1)
#include <input.c>
#include <24AA1025x4.c>
const char Version[]="1.0.F\0";
// Main
   BYTE value, cmd;
   int32 address;
   int8  device;
   delay_ms(300);
   printf("\r\n\n");
   printf("[RRBOARD2] EEPROM Commander %s\r\n",version);
   printf("based on 24AA1025 Microchip Hardware\r\n");
   printf("\xa9 10.2006 by RedPic\r\n\n");
   do {
      do {
         printf("\r\nDo you Read or Write? : ");
         cmd=getc();
         cmd=toupper(cmd);
         putc(cmd);
      } while ( (cmd!='R') && (cmd!='W') );
      printf("\n\rGive me EEPROM internal absolute Address (24 bits) in hex : ");
      address = gethex();
      address = (address<<8)+gethex();
      device  = memAbsoluteAddress2deviceAddress(address);
      if(cmd=='R')
         printf("\r\nReturn Value (8 bits) in hex is : %X\r\n",readByte24AA1025(address));
      if(cmd=='W') {
         printf("\r\nEnter new value (8 bits) in hex : ");
         value = gethex();
         printf("\n\r");
         writeByte24AA1025(address, value );
   } while (TRUE);
At last a executing view:
More details (in spanish) in AUX Quad-EEPROM I2C 512 Kbytes de EEPROM con cuatro 24AA1025
