		| View previous topic :: View next topic   |
			bsodmike
				| Referencing I/O Pins. |
				 Posted: Thu Sep 28, 2006 3:51 am     |
According to,
http://www.phanderson.com/PIC/PICC/CCS_PCM/tmr0.html
Even though that's very old it seems at CCS at a time supported referencing pins as
 	  | Quote: | 	 		  #define LED_FL_PIN rb3 	// RB3
#define SPKR_PIN rb2
#define LED_FL_DIR trisb3
#define SPKR_DIR trisb2 |
and performing,
 	  | Quote: | 	 		     SPKR_DIR = 0;  // make SPKR and LED_FL outputs
   LED_FL_DIR = 0;
   LED_FL_PIN = 0;
   SPKR_PIN = 0; |
In my current code I'm using something along the lines of,
#define xPin  PORTB.0
#define xTris TRISB.0
while defining
#define PORTA 0x05
etc etc
and that works. However, 'xPin=0;' doesn't work and I'm forced to use output_low(xPin);
Any ideas on this? |
			bsodmike
				 Posted: Thu Sep 28, 2006 5:18 am     |
				I've noticed another problem.
Even defining,
and
output_low(xPin); //doesn't work!
However, '#define xPin PIN_B0' causes it to work, as in the headerfile these are defined in the 'register*8+pin' format (so in this case 6*8+0, as 0x06 is the PORTB register.
Some googling and I found Phanderson's definitions for the 16f84,
 	  | Code: | 	 		  // DEFS_F84.H (CCS PCM)
// Definitions of file registers and bits.
// PIC16F84.  These agree with Microchip.
// Note that bits are lower case for C, upper case for assembly.
// copyright Peter H. Anderson, Scotland Co, NC, Mar, '99
// register definitions
#define W 0
#define F 1
// register files
#byte INDF          =0x00
#byte TMR0          =0x01
#byte PCL           =0x02
#byte STATUS        =0x03
#byte FSR           =0x04
#byte PORTA         =0x05
#byte PORTB         =0x06
#byte EEDATA        =0x08
#byte EEADR         =0x09
#byte PCLATH        =0x0a
#byte INTCON        =0x0b
#byte OPTION_REG    =0x81
#byte TRISA         =0x85
#byte TRISB         =0x86
#byte EECON1        =0x88
#byte EECON2        =0x89
#bit ra4   =0x05.4
#bit ra3   =0x05.3
#bit ra2   =0x05.2
#bit ra1   =0x05.1
#bit ra0   =0x05.0
#bit rb7   =0x06.7
#bit rb6   =0x06.6
#bit rb5   =0x06.5
#bit rb4   =0x06.4
#bit rb3   =0x06.3
#bit rb2   =0x06.2
#bit rb1   =0x06.1
#bit rb0   =0x06.0
#bit trisa4   =0x85.4
#bit trisa3   =0x85.3
#bit trisa2   =0x85.2
#bit trisa1   =0x85.1
#bit trisa0   =0x85.0
#bit trisb7   =0x86.7
#bit trisb6   =0x86.6
#bit trisb5   =0x86.5
#bit trisb4   =0x86.4
#bit trisb3   =0x86.3
#bit trisb2   =0x86.2
#bit trisb1   =0x86.1
#bit trisb0   =0x86.0 |
/me slaps head!  #bit/#byte, maybe these'll help, will test in a bit.
Update:  Works now, it was the #bit/#byte that sorted it out...
Thanks! |
