jgrauer
| SD card weirdness |
Posted: Thu Sep 28, 2006 7:52 am |
I've been trying the same setup everyone else has been using (http://www.cc5x.de/MMC/ for example), where I have a 3.3V power source to the SD, and then I use voltage dividers to get the PIC outputs down to 3.3V signals.
I can successfully read and write to the card, but only after I do a certain proceedure. The attached code (modified from http://www.ccsinfo.com/forum/viewtopic.php?t=27823&highlight=card) is what I use to just initialize and read from the card. When I first apply power to the SD card, I have to switch the MMC_DI and MMC_DO pins in software, try to intitialize, then switch the pins back and then everything works fine. Then I can sit and program just fine until I remove power to the MMC card, in which case I have to switch the pins again.
#include <18F452.h>
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7)
//Define New Pin Out
#define MMC_CS PIN_E0
#define MMC_CLK PIN_C3
#define MMC_DI PIN_C5
#define MMC_DO PIN_C4
#include<mmc_spi.c>
int8 buffer[512];
int16 size=512;
int32 address=0;
int8 *ptra;
int16 f;
int16 i;
//initialize buffer
for (i=0; i<512; i++)
buffer[i] = 0;
//set pointer
ptra = &(buffer[0]);
//initialization sequence
printf("\n\rInitializing SD drivers...\n\r");
if(mmc_init()==0)
printf("PASSED\n\r");
printf("FAILED\n\r");
address = 0;
while(input(PIN_A4));
while(!input(PIN_A4));
//read block
if(mmc_read_block(address, 512,ptra)==0)
printf("\n\rread ok\n\r");
printf("\n\rread fault");
//print the buffer
printf("\n\n\r 512 bytes starting at ADDRESS = %lu:\n\r", address);
for(f=0;f<=511;f++)
printf("%u ",buffer[f]);
address += 512;
output_low(PIN_B4);
output_high(PIN_B4);
Does anyone have any suggestions? Some mentioned something about the PIC powering down and not knowing where the SD card went. I'm using the CCS PIC18F452 protoboard right now.[/code] |
asmallri
Joined: 12 Aug 2004 Posts: 1675 Location: Perth, Australia
Posted: Thu Sep 28, 2006 8:52 am |
SD initialization code...
| Code: | DSTATUS SD_init(void)
// SD_init()
// Initialize the SPI bus and Memory card
int16 i;
BYTE Response;
DSTATUS SDCardStatus;
Card = none;
DeselectSD;
delay_ms(10);
SD_Flush_SPI();
if (SD_CD)
printf("ERROR - No Media Detected in the Socket\r\n");
return(STA_NODISK);
if (!SD_WP)
SDCardStatus = STA_PROTECT;
SDCardStatus = 0;
SelectSD;
Response = SD_cmd(SD_CMD_GO_IDLE_STATE,0);
if ((Response != 0x01) && (Response != 0))
printf("ERROR - Card not going into Idle state - Response = %x\r\n", Response);
DeselectSD;
return(STA_NOINIT | SDCardStatus);
// Maximum 500ms CMD1 (SD_CMD_SEND_OP_COND) to Ready
i = 0;
do
Response = SD_cmd(SD_CMD_SEND_OP_COND,0);
if (Response != 0x00 )
delay_us(100);
i++;
while ((!(Response==0x00)) && (i < 5000));
if(Response)
printf("Error - SD card failed to respond to CMD_SEND_OP_COND - Response = %x\r\n", Response);
DeselectSD;
// send an SD specific application command
// and see how the card responds
// printf("Attempting card type discovery by sending SD specific application command\r\n");
Response = SD_cmd(SD_CMD_APPL_CMD,0);
if (Response)
// if any response then the card cannot support application commands
// and therefore cannot be an SD card
printf("Non Zero response to SD Application command - must be an MMC Card\r\n");
Card = MMC;
// send SD_SEND_OP_COND
Response = SD_cmd(SD_CMD_SD_SEND_OP_COND,0);
if (!Response)
printf("OK response from SD specific command - indicates SD card\r\n");
Card = SD;
printf("Invalid response to SD Application command - trying MMC init sequence\r\n");
Card = MMC;
// reinitialise as MMC card
if ((Response !=0x01) && (Response != 0))
printf("Card reset failure - aborting SD card initialization\r\n");
DeselectSD;
// Completed card identification
switch (card)
case MMC :
printf("MMC Card found\r\n");
case SD :
printf("SD Card found\r\n");
default :
printf("Card Type Discovery Error - should never get here\r\n");
DeselectSD;
printf("Card reset success - Cmd to Ready count = %lu\r\n", i);
// set the SPI bus speed to high
setup_spi(spi_master | spi_l_to_h | spi_clk_div_4 | spi_xmit_l_to_h);
clear_interrupt(INT_SSP);
i = 0;
do
delay_us(100);
i++;
while ((!(Response==0x00)) && (i < 100));
if (Response != 0x00)
DUMMY++;
printf(" Card activate failure. Card Response = %X\r\n", Status);
DeselectSD;
DUMMY++;
printf(" Card activate success on attempt %lu\r\n",i);
DeSelectSD;
return(SDCardStatus);
_________________ Regards, Andrew
jgrauer
Posted: Thu Sep 28, 2006 9:03 am |
Thanks for the code, but I'm not sure how to use it. Where do functions(?) like Card, DeselectSD, SD_Flush_SPI, ..., come from?
Is it just a fluke that the MMC initialization file from CCS works with SD cards too? I was reading through the SD manual and it looked like the commands were the same.
Thanks! |
asmallri
Posted: Thu Sep 28, 2006 1:02 pm |
| jgrauer wrote: | | Thanks for the code, but I'm not sure how to use it. Where do functions(?) like Card, DeselectSD, SD_Flush_SPI, ..., come from? |
Card is a variable which holds the type of card information discovered by the SD_init() such as MMC, SD, Unknown
SelectSD and DeSelectSD are defined to assert and deassert the SD Cards CS input.
SD_Flush_SPI is a function to flush the SPI bus.
| Quote: |
Is it just a fluke that the MMC initialization file from CCS works with SD cards too? I was reading through the SD manual and it looked like the commands were the same.! |
The MMC commands are a subset of the SD command set however most embedded applications would simply use the common MMC command set, with one important difference being the initialization sequence. the SD_Init function determines the type of card are initializes it accordingly. If you are initializing an SD card using the MMC initialization sequence then you should not expect the card to function correctly. _________________ Regards, Andrew
jgrauer
Posted: Thu Sep 28, 2006 1:54 pm |
| Thanks a lot for your help. I think I'll just buy an MMC card instead. I was hoping to have something more or less work out of the box, and it looks like CCS's mmc_spi.c file will do that if I just use an MMC card... like the file says. |
