Teriyaki
Joined: 07 Sep 2006 Posts: 7 Location: Munich, Germany
signed or unsigned - this is the question |
Posted: Mon Sep 25, 2006 3:15 am |
Hi everybody !
Does a CCS C type specifier like int8, int16, int32 specify singed or unsigned numbers ?  |
Posted: Mon Sep 25, 2006 4:20 am |
To press the submit button only once - this is the request.
Please, remove the other two identical threads. You can do this as long as no-one has posted an answer in that thread.
Have you tried the search function of this forum before asking your question? If you had you would have found answers of many people asking the same question, for example http://www.ccsinfo.com/forum/viewtopic.php?t=23873&highlight=signed+unsigned
Or, ofcourse, you could try reading the compiler manual: Check the chapter on Type-Specifier, page 74 of the March 2006 revision of the manual. |
