ICD U40 as a Programmer
Jody
PostPosted: Fri Sep 22, 2006 9:05 am     Reply with quote
After debugging (works well) I can't program mine PIC (18F8722) with this ICD... I think there is something wrong with mine fuses but what???
I disabled ICD=TRUE compiled it again and uses the ICD.exe tool to program the PIC... It seems to go allright but mine program will not run...
Anybody a clue?????
I add mine fuses:
#include <18F8722.h>
//#device ICD=TRUE
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV25 //Brownout reset at 2.5V
#FUSES NODEBUG //No Debug mode for use with ICD
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES MCU //Microcontroller Mode
#use delay(clock=10000000)
