nested switch question
asmallri
PostPosted: Tue Sep 12, 2006 6:57 am     Reply with quote
If I have a sequence of nested switch statements can I break ou of this anywhere using a goto to the end of the function containing the statements without stuffing up the stack?
void myfunction()
     switch (j)
         case 1: switch (k)
                        case x: switch(l)
                                        case y: goto ErrorExit;
      ErrorExit:
Regards, Andrew
nurquhar
PostPosted: Tue Sep 12, 2006 7:24 am     Reply with quote
I think goto should work ok, the switch should all be done with inline stuff (however there is no rule that the compiler must do it this way!).
Check the compiler asm listing that the goto handles any long jumps across banks.
Since many people frown on the use of "goto" you could code the switches inside an #inline function and process a "return" from which ever cases you need.
eg
#inline int checkerr(int a, int b)
   switch (a) {
   case 0 :
      switch(b) {
      case 1 :
         return 1 ;
         break ;
      case 2 :
         return 2 ;
         break ;
      default :
         break ;
      break ;
   case 1 :
      switch(b) {
      case 1 :
         return 1 ;
         break ;
      case 2 :
         return 2 ;
         break ;
      default :
         break ;
      break ;
   default :
      break ;
   return 0 ;
void func()
   int err ;
   err = checkerr(1,2) ;
asmallri
PostPosted: Tue Sep 12, 2006 8:28 am     Reply with quote
I am one of those that frown on goto instructions however, in this case, the code is far easier to read and understand the flow instead of trying to work out which level of the case caded switch statements you are "break"ing out of.
Regards, Andrew
Mattr0
PostPosted: Tue Sep 12, 2006 1:44 pm     Reply with quote
I really frown on goto statements how about this
void myfunction()
short ex = 0;
     switch (j)
         case 1: switch (k)
                        case x: switch(l)
                                        case y: ex = 1;
      if(ex) {
        do whatever
When it get to case Y it will break out of both switch statements and chack if you set your flag and then run that code. It's a little cleaner and you don't have to worry about how the goto statement is going to work.
asmallri
PostPosted: Tue Sep 12, 2006 8:35 pm     Reply with quote
No it will only break out of the current case. It will then continue executing any statements remaining within the next outer layer and so on.
Regards, Andrew
