Davide Guest
| 16f877 i2c problems with master in interrupt. |
Posted: Fri Dec 07, 2001 5:31 am |
I have wrote this code for to transmit one byte, from slave to master with master i2c in interrupt:
*********************** MASTER *************************
#include <16F877.h>
#device PIC16F877 *=16 ICD=TRUE
#use delay(clock=8000000)
#fuses HS,NOWDT,PUT,NOLVP
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7)
#use i2c(master,sda=PIN_C4,scl=PIN_C3,SLOW,NOFORCE_SW)
#INT_SSP
void i2c_invia_a_slave()
*0x13 = 0x0F;
x=i2c_read (0);
disable_interrupts (INT_SSP);
i2c_stop ();
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_psp(PSP_DISABLED);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
enable_interrupts(global);
do
if (some event)
bit_clear (*0x0C, 3);
enable_interrupts(INT_SSP);
i2c_start();
} while (TRUE);
**************** SLAVE ********************
#include <16F877.h>
#use i2c(slave,sda=PIN_C4,scl=PIN_C3,address=0x0E,SLOW,NOFORCE_SW)
#INT_SSP
void i2c_ricevi_da_master()
byte incoming;
if (i2c_poll()==TRUE) incoming = i2c_read ();
else i2c_write (25);
do{}while (TRUE);
The problem is that first transmission is ok, the master receives the number 25, but the slave remain blocked on the instruction i2c_write (25); and if I try to transmit an other time, the master jams also in the instraction i2c_start ();.
The same problem there is also when the master is implemented not in interrupt. The solution in this case is to add the "OPTIONAL ????" parameter zero in the instruction i2c_read(0); to cause the function to not ACK the received data.
This solution does not work with master in interrupt.
how I can make?
IDE 2.32
PCB 2.734
PCM 2.734
___________________________
Original Post ID: 1499 |
Tomi Guest
| Re: 16f877 i2c problems with master in interrupt. |
Posted: Sat Dec 08, 2001 3:49 pm |
Hi Davide,
I don't find the slave address at your master side.
To read a byte, you must:
i2c_start();
i2c_write(0x0F); // 0x0E the slave address base, so send out 0x0F for reading
etc.
So you need a phase counter or same and send out the slave address (bit0=1) as the first byte from your ISR.
Original Post ID: 1520 |
Davide Guest
Posted: Mon Dec 10, 2001 3:11 am |
:=Hi Davide,
:=I don't find the slave address at your master side.
:=To read a byte, you must:
:=i2c_start();
:=i2c_write(0x0F); // 0x0E the slave address base, so send out 0x0F for reading
:=etc.
:=So you need a phase counter or same and send out the slave address (bit0=1) as the first byte from your ISR.
Hi Tomy, sooner or later I will have to offer a pizza to you, if you come in Italy, or if I come.... (where do you live?).
Instead writing i2c_write (0X0F);
I wrote *0X13 = 0x0F;
Because, else the Master don't repeat the interrupt at the end of the i2c_write instruction (this method is one of your suggestions that work fine).
At this point the problems remain the same.
#include <16F877.h>
#INT_SSP
void i2c_master()
*0x13 = 0x0F; //****************************** HERE
x=i2c_read (0);
i2c_stop ();
do
if (some event)
i2c_start();
} while (TRUE);
#include <16F877.h>
#INT_SSP
void i2c_slave()
byte incoming;
do{}while (TRUE);
Bye,
Davide.
IDE 2.32
PCB 2.734
PCM 2.734
Original Post ID: 1537 |
Davide Guest
| SORRY |
Posted: Mon Dec 10, 2001 3:17 am |
Excuse Tomi I mistake always your name.
Original Post ID: 1538 |
Davide Guest
Posted: Mon Dec 10, 2001 7:26 am |
#include <16F877.h>
#INT_SSP
void i2c_master()
x=i2c_read (0);
i2c_stop ();
do
if (some event)
i2c_start();
} while (TRUE);
#include <16F877.h>
#INT_SSP
void i2c_slave()
byte incoming;
do{}while (TRUE);
Bye,
Davide.
IDE 2.32
PCB 2.734
PCM 2.734
Original Post ID: 1540 |
Tomi Guest
Posted: Mon Dec 10, 2001 12:00 pm |
<font face="Courier New" size=-1>:=Hi Tomy, sooner or later I will have to offer a pizza to you, if you come in Italy, or if I come.... (where do you live?).
Hungary. OK, Sir, let's say that you have sent a virtual pizza for me (an original, "fried-on-stone" , Quattro Staggioni or Cardinale with extra cheese). And don't worry about my name: you can write Thomas, Tomasso, Tomi, Tomassino, Tomy, etc.
:=Instead writing i2c_write (0X0F);
:=I wrote *0X13 = 0x0F;
OK, I'm a blind mouse with two eye-glasses and I forgot to change it to the right one.
And now the problem. I have tried your code in my old CCS C version (2.734) and I have seen that the optional parameter for i2c_read() doesn't matter. If you want to use the NACK as the end of the transfer, try this:
#INT_SSP
void i2c_master()
bit_set(*0x91,5); // set NACK
x = i2c_read();
bit_set(*0x91,4); // set ACKEN to init an ACK cycle
while (!bit_test(*0x0C,3)) ; // wait for ACK end
bit_clear(*0x0C,3);
i2c_stop ();
Hope this helps. If not, I'll be here usually after 6:00PM (we are in the same time zone).
</font>
Original Post ID: 1545 |
Posted: Sun Jun 11, 2006 9:02 am |
| Davide wrote: | :=Hi Davide,
:=i2c_start();
:=etc.
#include <16F877.h>
#INT_SSP
void i2c_master()
x=i2c_read (0);
i2c_stop ();
do
if (some event)
i2c_start();
} while (TRUE);
#include <16F877.h>
#INT_SSP
void i2c_slave()
byte incoming;
do{}while (TRUE);
Bye,
Davide.
IDE 2.32
PCB 2.734
PCM 2.734
domdom
Posted: Wed Sep 06, 2006 9:13 am |
Are they working? i mean master and slave c code?
then how you programme into your MCU?
the MCU(master) programme with the master c code? the slave MCU programme with the slave c code? |
cjusto
Posted: Thu Sep 07, 2006 1:45 pm |
hey ragazzo italiano.
i think you should implement the master without interrupt. if u need that contious, than it will work.
the nack in the end is very important.
cya around! |
