bwgames
				| Counter problems |
				 Posted: Wed Sep 06, 2006 2:33 am     |
				I have the below code to read from an EEPROM and output several lines at once (rather than having to read the EEPROM for each line which slows  it down), yet I don't get any output apart from:
"j= "
Any ideas?
int32 i;
int32 j;
int32 number;
char X_array[10];
char Y_array[10];
char Z_array[10];
number = 5000; //can change
i=0;
j=0;
do {
while((j<8)&&((i-7)<number))
X_array[j] = read_eeprom_byte(framWrite[0],framRead[0],addr+i);
Y_array[j] = read_eeprom_byte(framWrite[1],framRead[1],addr+i);
Z_array[j] = read_eeprom_byte(framWrite[2],framRead[2],addr+i);
j++;
i++;
}//end of if j<8
fprintf(Wireless,"\n\rj= %Lu\n\r",j); //debugging output
j=0;
fprintf(Wireless,"%Lu,%i,%i,%i\n\r",(i-7),X_array[j],Y_array[j],Z_array[j]);
j++;
j=0;
} while((i-7)<number);
			treitmey
  Joined: 23 Jan 2004 Posts: 1094 Location: Appleton,WI   USA
				 Posted: Wed Sep 06, 2006 8:31 am     |
				From the help file
 	  | Quote: | 	 		  | Note: All types, except float, by default are unsigned |
Thus int32 is unsigned.
you never enter while loop because
i=0
i-7=04294967289   //remember i is unsigned so subtraction wraps to a pos number
(i-7)<5000) fails |
