Joined: 12 Aug 2004 Posts: 1678 Location: Perth, Australia
Automated device select in PCH
Posted: Thu Aug 31, 2006 12:53 am
I use PCH inside MPLAB. I have applications that support multiple hardware platforms. Currently to compile an image I set a flag in the source code to select the target platform plus select the target PIC from MPLABs configure window. How can I embed the target PIC info into the source such that I do not have to manually reconfigure MPLAB each time I select a new target platform in my source code? _________________ Regards, Andrew
You can also throw in fuse lines device lines etc into the various blocks...
asmallri
Posted: Thu Aug 31, 2006 5:07 am
This was the mechaism I tried but it does not work correctly.
For example if I specify a PIC18F8722 both in the code (as per your example) and as the device in the config window the code compiles correctly however if I select some other 18F family processor in the configure device menu like a PIC18F24J10 and select PIC18F8722 in the code then I get an error message of the form "The Extended Mode Configuration bit is enabled but...." _________________ Regards, Andrew
