mkr
| "Could not run program: The COM buffer is too small&quo |
Posted: Tue Aug 15, 2006 2:25 pm |
Hello All,
I am facing this unique issue such as "Could not run program: The COM buffer is too small" when using the CCS compiler. I have setup the hardware with the ICD-S40 as one COM port of PC. I am using another COM port to transmit data(like a hyper terminal app.) to my hardware. When I ever I do an in circuit debug, I have the above message from the compiler. Hence my debugging takes longer time to figure out issues. I am using CCS compiler (ver.PCH 3.241 and IDE ver 3.212).
Is there anyother way to avoid this message. _________________ Thanks
mkr |
