HMC6352 Compass Driver
Post new topic   Reply to topic    CCS Forum Index -> Code Library
Gerhard
PostPosted: Sat Sep 06, 2008 8:46 pm     Reply with quote
Thought I'll just move the code here as it is ready to use on the pic's.
#include <16F877A.H>
#use i2c(Master, sda=PIN_C4, scl=PIN_C3, FORCE_HW)
#define HMC6352_I2C_WRITE_ADDRESS 0x42
#define HMC6352_I2C_READ_ADDRESS  0x43
#define HMC6352_GET_DATA_COMMAND 0x41
// Read the compass heading.  This is in units
// of 1/10's of a degree, from 0 to 3599.
int16 HMC6352_read_heading(void)
int8 lsb;
int8 msb;
i2c_start();
i2c_write(HMC6352_I2C_WRITE_ADDRESS);
i2c_write(HMC6352_GET_DATA_COMMAND);
i2c_stop();
delay_ms(7);  // Allow 1 ms extra for safety
i2c_start();
i2c_write(HMC6352_I2C_READ_ADDRESS);
msb = i2c_read();
lsb = i2c_read(0);
i2c_stop();
return((int16)lsb | ((int16)msb << 8));
int16 heading;
   heading = HMC6352_read_heading();
   printf("Heading in degrees = %lu\n\r", heading/10);
hasimi20
PostPosted: Sun Sep 05, 2010 3:08 am     Reply with quote
does this code really run successfully??
i am afraid to try it because the compass module is very expensive in my country
Bisnouk
PostPosted: Tue Sep 14, 2010 1:40 am     Reply with quote
The HMC6352 is very easy to use with PIC. I have still 8 Sparkfun modules is my house, I don't use and I sell them.
But it does not have tilt compensation and as it has only two magnetic axes, you cannot use an external tilt sensor. Also, the heading is wrong if the module is not horizontal. For my automotive module, it wasn't the good sensor.
So, I'm using HMC6343 with integrated tilt compensation. The first release was not good, so I waited for one year and at the beginning of 2010 year, it was ok. Honeywell datasheet is a bit poor (and with some mistakes). I spent much time to correct calibration routine but now, it is fully stable.
For example, my automotive module:
hasimi20
PostPosted: Wed Oct 06, 2010 6:15 pm     Reply with quote
Wow.. its sounds good!!!! Good job bisnouk.
Can you share the HMC6343 simple source code??? It will help the other compass module users out there!!!
Best regards
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
