Version 4 Comments
Goto page Previous  1, 2, 3 ... 9, 10, 11 ... 17, 18, 19  Next
Richard Arroyo
PostPosted: Sat Nov 04, 2006 1:48 am     Reply with quote
I was writing a program for an 18f452 used in a test fixture to monitor a few analog lines and frequency. A few floats and 8 bit variables were used. Using PCHW 3.249 the program complied and worked fine until I added one more variable. The pic would then hang up on the first Delay_ms() function. Only 20% ROM and 8% RAM was used. I tested program using PCHW 4.013 and it worked perfectly despite all of it's issues. This is a fairly simple program and I've written FFT and DFT algorithms using PCHW 3.249 with no problems. I'll have to analyse the ASM output list to see where the fault lies.
I have been asking CCS about 33F and 24F support.
Hopefully, next year support might be available.
Expect it to be bugged up a little.
I suppose If I get impatient I could pop
$1k on MPLAB C30 or HI-TECH dsPIC.
I could write my own dsPIC C compiler but
with time I have available it would be a while.
RAA
Richard Arroyo
PostPosted: Tue Nov 07, 2006 7:32 pm     Reply with quote
I was able to find time to continue where I left off.
Somehow the .hex output file was being badly corrupted.
Today, I recompiled with v3.249 and no corruption occurred. Perhaps there was garbage in my computer's ram at the time of the problem.
RAA
Dinesh
Version 4.015 IDE Problem
PostPosted: Sat Nov 18, 2006 4:27 pm     Reply with quote
Version 4.015 has caused frustrating problem, repeatable on two different workstations (one XP Pro SP2 and Windows 2000 SP4).
On opening a project and trying to select the first document creates a problem.
The document is already loaded as per last state. By clicking in the workspace editor area, I get access violation at in the module pcw.exe at same point on both system at 004D71E5 in module pcw.exe Mad
The only way to over come this is manually select the editor area using keyboard - tabs etc. (i.e. don't click on editor area to begin edit). Once in the editor, you can make changes. There after, the clicking to select the document works! Confused
W2k sp4 512MB (Motherboard:ASUS A7S8X)
RSO
PostPosted: Sat Nov 18, 2006 8:37 pm     Reply with quote
Thanks for the suggestion. It works.
Billy
Annoying IDE behaviour
PostPosted: Mon Nov 20, 2006 12:01 pm     Reply with quote
When I put a tab in my code on a line with no other text the IDE deletes the tab when I move to a new line. I'm finding this very frustrating, possibly because of the way I write code, but I don't see why it needs to do this - I frequently add tabs to blank lines within functions prior to writing code and they used to stay where they were. Its like using MS Word in the way it descides these things for you.
Anyone else find this little issue annoying, any chance of it being 'fixed'
Oh and by the way the DSPics I bought a while ago in anticipation of being able to write C code for them have started to fossilise . . .
Richard Arroyo
PostPosted: Wed Nov 22, 2006 1:21 am     Reply with quote
Well, I've started using Microchip's C30 compiler and it's not all that bad; however, it's rather clunky getting everything set up for the first time.
The manuals and data sheets are spread across 10, 700 page pdf's. The MPLAB IDE is simple, efficient and doesn't try to figure out what one is doing while typing (Microsoft paperclip mode).
Of course you get more bang for the buck with the CCS
PCWH package and it's better suited for smaller projects. I just hope the CCS v4 compiler doesn't turn into a lead weight.
I've managed to program a dsPic30f4013 ok. At 30MIPs those IC's draw around 160ma and get toasty warm Very Happy .
RAA
noizy
The lovely V4 IDE
PostPosted: Wed Dec 13, 2006 10:27 am     Reply with quote
Very Happy
Finally, I finished a large 18F4550 project with V4: Instead of buying a large pack of spam to survive using the V4 editor, I switched to MPLAB with just the CCS PCWH compiler. No more TAB or UNDO headaches, no lost sourcecode - I should have dumped the V4 IDE earlier.
The only drawback is the missing mouse-over-variable function in the MPLAB debugger.
neil
Addressmod?
PostPosted: Wed Dec 13, 2006 10:54 am     Reply with quote
Have CCS abandoned addressmod or typemod completely? I am assuming somebody has actually reported it formally to them as being broken? It was mentioned near the beginning of this post. The problem being that it never makes the calls to the read/write functions, so returns garbage!
It would be really convenient to use for storing non-volatile variables to EČ without having to worry about placing them there manually! ie. being lazy!! Very Happy
Neil.
treitmey
PostPosted: Wed Dec 13, 2006 12:23 pm     Reply with quote
Yes I sent them the bug. the email ref below is ccsstatus_at_ccsinfo.com (replace__at_)
Should you wish to check on the status of your e-mail, you can
send another e-mail with the subject line:
{6H6361}
This will cause an automatic response during business hours. Please do not include any other information in these messages as
they will be discarded without being read.
The current status is as follows:
Your e-mail has been assigned to someone in C Tech Support.
The e-mail has been reviewed, however, an answer is not
yet ready. A priority has not yet been determined for this issue.
CODE EDITED
#include <16F877A.h>
#device *=16
#fuses hs,nowdt,noprotect,nolvp,put
//#use delay(clock=20000000)
#use delay(clock=11059200)
#use rs232(baud=19200,xmit=PIN_E2,invert,stream=debug,disable_ints)
#case
#zero_ram
void DataEE_Write(int32 address, int8 * data, int8 size){
  //fprintf(DEBUG,"W-A=%lu, S=%u\n\r",address,size);
  fprintf(DEBUG,"Write\n\r");
void DataEE_Read(int32 address, int8 * data, int8 size){
  //fprintf(DEBUG,"R-A=%lu, S=%u\n\r",address,size);
  fprintf(DEBUG,"Read\n\r");
typemod <,DataEE_Read,DataEE_Write,0x00,0xFF> DataEE;
//addressmod (DataEE,DataEE_Read,DataEE_Write,0x00,0xFF);
char DataEE addr;
main(){
  //char DataEE addr;
  int8 temp;
  fprintf(DEBUG,"Start\n\r");
  addr=35;//write
  temp=addr;//read
  fprintf(DEBUG,"T=%u\n\r",temp);
Storic
PostPosted: Wed Dec 13, 2006 4:17 pm     Reply with quote
from the above code I change
typemod <DataEE_Read> DataEE;
to:
typemod (DataEE,DataEE_Read,DataEE_Write,5,0xff);
as per the help example (typemod)
// addressmod (name,read_function,write_function,start_address,end_address);
addressmod (DataEE,DataEE_Read,DataEE_Write,5,0xff; // would define a region called DataEE between
It compiles OK however I dont know if this is correct, I have never used typemod and would not know what to expect when testing.
ANdrew
What has been learnt if you make the same mistake? Wink
treitmey
PostPosted: Wed Dec 13, 2006 4:36 pm     Reply with quote
I edited the above code((3 times)) got it through my thick head the HTML
checkbox problem was bitting me.
compiling isn't the issue, calling the write function is the issue.
V3.249 works OK
Start
Write
Read
T=0
V4.017 is bad, no write
Start
Read
T=0
Storic
PostPosted: Fri Dec 15, 2006 6:44 am     Reply with quote
Yes I see what you are saying.
I looked at the ASM under 4.018 amd 3.249 and yes no ASM on the "void DataEE_Write(int32 address, int8 * data, int8 size)" however I try the following.
as there was no write when I reversed DataEE_Read and DataEE_Write, to
typemod (DataEE,DataEE_Write,DataEE_Read,5,0xff);
I now seen the write however but no read.
hmmm! Confused
ANdrew
Storic
PostPosted: Fri Dec 15, 2006 7:57 am     Reply with quote
some more additional information. I can force the compiler to give me the write code by adding "DataEE_Write(0,0,0);" in the Main Prog, (initializing)
now the ASM has the code for "DataEE_Write"
#device *=16
#case
#zero_ram
char DataEE addr;
main(){
  //char DataEE addr;
  int8 temp;
//  DataEE_Read(0,0,0);
  DataEE_Write(0,0,0); // added to force the ASM conversion
  addr=35;//write
  temp=addr;//read
Confused Confused Confused
Even thoe I can force the code to see the DataEE_Read/write, I cant get the "addr=35;//write" to work (no ASM generated.)
ANdrew Rolling Eyes
what do i do now?
PostPosted: Thu Dec 21, 2006 10:01 am     Reply with quote
Just ordered version 4 Pcw only to find out that its version 3 that don't have the bugs
i have only got a 30 day update as i can't afford to buy for a year
when the bugs finally gets sorted my 30 days would have being over
what would you do if you are in my shoes
Donna
pirev
View user's profile Send private message Visit poster's website ICQ Number
4 is to ugly and and uncomroftable
PostPosted: Fri Dec 22, 2006 5:07 am     Reply with quote
Versions 4.xxx are horror IDE, I can't see such IDE from yers Evil or Very Mad They are to ulgy and uncomfortable Rolling Eyes Why CCS was drop IDE interface from previous versions ? After every switch to another application, 4.xxx IDE lost input focus and user must click with mouse to get input focus.
And these big menus, they are used to mach space from display.
This is too uncomfortable ... I don't have words.
I was switched back to 3.249 IDE while CCS IDE will stand friendliness. I will use CCS C compiler versions 4.xxx only with MPLAB.
I'm sorry, but this is horror IDE ...
Page 10 of 19
