Software I2C using porta on 16f877a problem
shew82
PostPosted: Tue Jul 25, 2006 2:56 am     Reply with quote
I am trying to create a software I2C port to use two pins on porta of the 16f877a i'm using (PIN_A3=SDA, PIN_A2=SCL). I cannot use the standard C3/C4 pins as these are in use for a SPI connection. For some reason I am getting nothing out of the pins (using a scope to check the output).
To program the device I'm using a ICD2 and I'm using v3.215 of CCS.
In an effort to try to find out why I cant seem to get this to work I have stripped out the rest of my program and left myself with the following code:
#include "16F877.h"
#device ICD=TRUE
#fuses RC, NOWDT, NOPUT, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#use delay (clock=4000000)
#use i2c ( MASTER, SDA=PIN_A3, SCL=PIN_A2, SLOW=50000)
short     loopForever=1;
void main ()
     setup_adc_ports(NO_ANALOGS);
     set_tris_a(0x00);
     while (loopForever==1) {
          i2c_start();
          i2c_write(0x0A);
          i2c_write(0x0A);
          i2c_write(0x0A);
          i2c_write(0x0A);
          i2c_stop();
If anyone has any ideas, I would be most grateful,
Shaun
PostPosted: Tue Jul 25, 2006 4:12 am     Reply with quote
Obvious first comment, have you got the pull-up resistors?.
I'd get rid of the TRIS statement.
The way software I2C is done, is that the port is programmed to pull 'down', and then the tris bit is set to '1' (input), to give a high out (pulled up by the resistors), or to '0' to drive the pin low. I2C, wants to start with the two pins _high_, which requires the TRIS to be set as inputs, not outputs. Though the latter data should appear (the code will be changing the TRIS), you will not get the 'start' bit pattern, since the lines have been driven by your TRIS statement.
shew82
PostPosted: Tue Jul 25, 2006 4:30 am     Reply with quote
I knew there must have been something obvious that i'd missed!
I'm currently using a standard pic development board (until a more specialist board has been made) which lacks pull-ups on A2 and A3... so tried using A0 and A4 (both pulled up) and voila! working like a charm!
All I need to do now is check that the board thats being made has appropriate pull-ups as well...
Thank you for you quick reply :-)
Shaun
