asmallri
Joined: 12 Aug 2004 Posts: 1673 Location: Perth, Australia
| What am I doing wrong with this syntax? |
Posted: Tue Jul 18, 2006 10:18 am |
With the following data structure
/* Directory object structure */
typedef struct _DIR {
DWORD sclust; /* Start cluster */
DWORD clust; /* Current cluster */
DWORD sect; /* Current sector */
WORD index; /* Current index */
} DIR; |
If I have the following declaration:
FRESULT f_stat (
char *path, /* Pointer to the file path */
FILINFO *finfo /* Pointer to file information to return */
FRESULT res;
BYTE *dir;
DIR dirscan; // <==== ERROR
char fn[8+3+1] |
The code fails compiling with a "Code has no effect" error.
However if I reorganize it like this it compiles ok
| Code: | FRESULT f_stat (
DIR dirscan; // <==== NO ERROR
FRESULT res;
BYTE *dir;
char fn[8+3+1] |
[/code]
Second problem
static
char make_dirfile (
char **path, /* Pointer to the file path pointer */
char *dirname /* Pointer to directory name buffer {Name(8), Ext(3), NT flag(1)} */
The compiler spits the dummy at char **path but does not mind the following:
typedef char* pchar;
pchar *path;
They should be equivalent. _________________ Regards, Andrew
Posted: Tue Jul 18, 2006 11:48 am |
| I can't do anything without a test program. |
asmallri
Posted: Tue Jul 18, 2006 6:35 pm |
Thanks - I found the first one. I ported someone elses code to CCS and I didn't realise they have used case to differentiate labels. Such as DIR and dir _________________ Regards, Andrew
