ICD-U40.exe shows only COM port3
bsb4
PostPosted: Wed Jun 21, 2006 3:41 am     Reply with quote
Hi all!
I'm using PCWH compiler v3.235 to program and debug my 18F4550 PIC board. While i am able to burn the program using the debug mode, but when i try to burn it using icd-u40.exe it only shows a com3 port and no usb ports.
I get the error message: "Could not connect: No response from icd, check connection and power to ICD".
Is this because i'm using windows XP?
Some solution please.......
treitmey
PostPosted: Wed Jun 21, 2006 8:14 am     Reply with quote
Unplug the USB and RePlug it in. It may have lost the USB connection.
Xp works fine.
Inside the ICD-U40 is a FTDI chip. It does the USB to serial conversion.
Are you using any of these chips.
Can you go into the device manager a find the PID and VID under the USB/ICD-U40/properties/details?
bsb4
PostPosted: Thu Jun 22, 2006 1:16 am     Reply with quote
VID=0461
PID=0020
I dont think that its a problem of usb connection, its just that it has never worked independently (i.e; the icd.exe)
