PICoHolic
[Resolved] Strange TMR1 32,768Khz RTC |
Posted: Sun Mar 01, 2009 4:45 am |
I've been facing strange timings when using TMR1 with external 32,768Khz XT (RC0, RC1).
PORTD,5 should have a frequency of 0.5Hz but I'm reading 2.918Hz.
Please note that i dont have capacitors on the 32,768Khz XT.
device: 18LF4620 running on 3V Li Battery
compiler: 4.086
#include <18F4620.h>
#device adc=8
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#use delay(clock=8000000)
#use i2c(Master,Fast=400000,sda=PIN_D1,scl=PIN_D0, FORCE_SW)
#byte PORTA = 0xF80
#byte PORTB = 0xF81
#byte PORTC = 0xF82
#byte PORTD = 0xF83
#byte PORTE = 0xF84
#byte OSCTUNE=0xF9B
#byte OSCCON= 0xFD3
#bit IDLEN = OSCCON.7
#Byte TMR1H = 0xFCF
#Byte T1CON = 0xFCD
#use fast_io (A)
#int_TIMER1 //Real Time Clock
void TIMER1_isr()
bit_clear(T1CON,7);
Bit_Set(TMR1H,7);
Bit_Set(T1CON,7);
Sflg=true;
#asm btg PORTD, 5 #endasm
void delay_s(int8 s)
while(s--)
Sflg = false;
while(!Sflg);
void InitPorts (void)
set_tris_a(0x04);
PORTA = 0x21;
set_tris_b(0x0F);
PORTB = 0x00;
port_b_pullups (TRUE);
set_tris_c(0x93);
PORTC = 0x00;
set_tris_d(0x03);
PORTD = 0x84;
set_tris_e(0x00);
PORTE = 0x00;
setup_oscillator(OSC_8MHZ|OSC_IDLE_MODE|OSC_31250|OSC_PLL_OFF);
delay_cycles(4);
setup_psp(PSP_DISABLED);
setup_spi(SPI_MASTER|SPI_XMIT_L_TO_H|SPI_L_TO_H|SPI_CLK_DIV_4);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_CLK_OUT);
setup_vref(FALSE);
InitPorts();
Any thoughts?
Thanks |
PICoHolic
Posted: Sun Mar 01, 2009 6:25 am |
hmmm,
27 pF caps are a must  |
Posted: Sun Mar 01, 2009 9:10 am |
First comment, simplify.
What you have posted, could easily be written in half the lines, loads of bloat that is not helping to see what is going on, but at the same time, is not complete, so can't be the actual code you are running (Sflg, is not defined anywhere...)...
Code should be simple, and complete.
Personally, I'd do something much simpler.
Just set the timer to zero, pause for 100mSec, and read the timer. If the value read is below 6400, set one bit, if it is above 6700, set another (I'm assuming your serial is not connected, otherwise just print the value read). If either bit comes on, you can tell that your timer clock _is_ off frequency, and start looking at this.
PICoHolic
Posted: Sun Mar 01, 2009 9:16 am |
Thanks,
But I wrote the first comment
And now it's working. I just had to add these two caps. |
Posted: Sun Mar 01, 2009 10:57 am |
I'm not surprised. The slim 32K crystals, though fundamental types, rather than overtone units, actually have two fundamentals. One corresponding the to width of the crystal, and the other the length. The ratio is typically about 5:1. The internal oscillator will try to lock onto the higher frequency...
Without the right loading, there is no point in ever using a crystal.
Your post didn't appear on my system, till after I posted. A common 'oddity'.
However I would suggest doing lots of things more efficiently. Why keep toggling the timer between 16bit and 8bit modes?. Just set it to 8bit mode once. Do this with something like:
#Byte TMR1H = 0xFCF
#Byte T1CON = 0xFCD
#bit T1_16bit = T1CON.7
#bit Msb =TMR1H.7
//Just set T1_16bit=false in the main code once
//The ISR then becomes:
void TIMER1_isr()
Msb=true;
Sflg=true;
output_toggle(PIN_D5);
You can also get rid of most of the setup code shown. Large parts of this are the default settings.
PICoHolic
Posted: Sun Mar 01, 2009 11:58 am |
Thanks  |
