Building MPLAB project at Command Line
PostPosted: Fri Jun 02, 2006 10:28 am     Reply with quote
I'm new to MPLAB and I'm trying to build a project (.mcw file) from the command line (instead of the MPLAB GUI) and I don't know where to begin. Ideally I'd like to create a batch file to do this. Would someone be able to tell me the commands to type in DOS to build a project?
Much appreciated...
- JB
PostPosted: Fri Jun 02, 2006 10:30 am     Reply with quote
It would also be great if someone could mention how to run the program from the command line after compiling it. Thanks again!
- JB
Humberto
PostPosted: Fri Jun 02, 2006 11:13 am     Reply with quote
I suggest you to ask for this in the Microchip forum. This forum is supported and managed
by CCS and is related to its C Compiler and PIC microcontrollers ONLY.
You will find sub forums MPLAB related.
http://forum.microchip.com/
Humberto
PostPosted: Mon Jun 05, 2006 11:35 am     Reply with quote
Thanks!
