macobt
| Please someone to compile this... |
Posted: Fri Feb 19, 2010 10:24 am |
Hello
Please someone to convert this code into hex code.
* Binary Watch
* by Mastro Gippo
* (c) 2008
#include "main.h"
#define RowH PIN_A1
#define RowM PIN_A2
#define PwmDel delay_us(0)
int1 OnLed;
int8 Seconds = 0;
int8 Hours = 0, Minutes = 0;
void PrintRows(int8 R1, int8 R2);
#int_RTCC
void RTCC_isr(void)
Seconds++; // Increment number of seconds
if(Seconds == 60) {Minutes++; Seconds = 0;
if(Minutes == 60) {Hours++; Minutes = 0;
if(Hours == 24) {Days++; Hours = 0;
int8 Pse;
int8 Cnt;
//Setup...
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
enable_interrupts(INT_RTCC);
port_a_pullups(FALSE);
output_low(RowH);
output_low(RowM);
output_low(PIN_C0);
output_low(PIN_C1);
output_low(PIN_C2);
output_low(PIN_C3);
output_low(PIN_C4);
output_low(PIN_C5);
#use fast_io(A)
set_tris_a(0xF9);
#use fast_io(C)
set_tris_c(0x00);
Hours = 13;
Minutes = 1;
if(input(PIN_A0)) //Button pressed; Show time
Pse = Seconds;
Cnt = 5; //Show time for 5 seconds
while(Cnt > 0)
if(Seconds != Pse)
Pse = Seconds;
Cnt--;
PrintRows(Minutes, Hours);
//If button is still pressed after 5 seconds, set up
if(input(PIN_A0))
output_high(RowM);
output_c(0x20);
delay_ms(2000);
output_c(0x00);
output_low(RowM);
Pse = Seconds;
Cnt = 4;
while(Cnt > 0)
if(input(PIN_A0)) //Increase minutes every button press
Cnt = 4;
delay_ms(10); //Simple debounce
Minutes++;
if(Minutes == 60)
Minutes = 0;
//Shows current setting, while waiting
//for the user to release the button
while(input(PIN_A0)){PrintRows(Minutes, 0);};
//If the user doesn't press the button for 4sec,
//switch to Hour setting
if(Seconds != Pse)
Pse = Seconds;
Cnt--;
Pse = Seconds;
Cnt = 4;
while(Cnt > 0)
if(input(PIN_A0))
Cnt = 4;
delay_ms(10);
Hours++;
if(Hours == 24)
Hours = 0;
while(input(PIN_A0)){PrintRows(0, Hours);};
if(Seconds != Pse)
Pse = Seconds;
Cnt--;
Pse = Seconds;
Cnt = 5;
while(Cnt > 0)
if(Seconds != Pse)
Pse = Seconds;
Cnt--;
static int8 i;
output_low(RowH);
output_high(RowM);
//I have only one resistor, so I must
//turn on only one led at a time
#use fast_io(C)
output_c(R1 & 0x01);
output_c(R1 & 0x02);
output_c(R1 & 0x04);
output_c(R1 & 0x08);
output_c(R1 & 0x10);
output_c(R1 & 0x20);
output_low(RowM);
output_high(RowH);
output_c(R2 & 0x01);
output_c(R2 & 0x02);
output_c(R2 & 0x04);
output_c(R2 & 0x08);
output_c(R2 & 0x10);
output_c(0);
output_low(RowM);
output_low(RowH);
Here is web site with the project I want to build:
http://www.mastrogippo.it/2008/09/yet-another-binary-watch/
But I know to program just with hex codes. The chip is PIC16F688.
Regards macobt |
