| communicating with GPS receiver |
Posted: Wed May 17, 2006 10:01 am |
I am trying to communicate with a GPS receiver using PIC16F873. But I am not able to receive the data out of it. On the contrary, it prints out data which I am not able to recogonize.
I am not that good in programming and I apologize for any basic mistakes.
My code is as follows:
#include <16F873.h>
#fuses XT, NOPROTECT, NOLVP, NOCPD, NOWRT, NOBROWNOUT, NOPUT,NODEBUG,NOWDT
#use rs232(baud=4800,parity=N,xmit=pin_c0,rcv=pin_c1,bits=8,stream=GPS,errors)
#use rs232(baud=4800,parity=N,xmit=pin_c6,rcv=pin_c7,bits=8,stream=output,errors)
char c;
char gpsdata[30];
int i;
#int_rda
void rda_isr()
i = 0;
for (i = 0; i <= 30; i++)
c = fgetc(GPS);
gpsdata[i] = c;
while(true)
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
enable_interrupts(global);
enable_interrupts(int_rda);
fprintf(output, gpsdata[i]);
and the output in the hyperterminal is as follows:
(ìP»‘Ú÷ 5ÁÙ5Á5Á‘×(ûP(ìP»‘Ú÷ 5ÁÙ5Á5Á‘×(ûP
When I use a fputc command instead of fprintf, the printed data is diffirent , but again they are also garbage values.
Please help me out.
Thanks,
noviceprogrammer. |
Posted: Wed May 17, 2006 10:27 am |
The immediate problem is that #int_rda only works with the hardware
UART. You have assigned a soft UART (pins C0 and C1) to the GPS
stream. So it can't work.
You need to switch the streams. The hardware UART is always on
pins C6 and C7 in the 16F873. Change it to be the GPS stream.
Put the "output" stream on pins C0 and C1.
Also, your #int_rda function is not done in the best way. Normally,
you only get one character per pass through the #int_rda function.
That's because it will give you one interrupt per character. Do a
search on the forum for "GPS". There are probably several posts
that hopefully show how to do it better. |
Posted: Thu May 18, 2006 4:51 pm |
| Thanks very much. It was useful. If I wish to retain the C0 and C1 pins for my GPS stream can I use 'int_ext' interrupt instead of int_rda?? |
Posted: Thu May 18, 2006 5:35 pm |
Yes, you can use the External interrupt pin to detect the start bit of an
incoming character on a soft UART. Then you can call fgetc() inside
the INT_EXT isr to get the character.
However, if for some reason you can't service the INT_EXT interrupt
quickly enough, you will lose the incoming character. This could happen
if you have interrupts disabled, or if another interrupt (such as INT_RDA)
is being serviced. |
Posted: Thu May 18, 2006 5:59 pm |
Thankyou very much. I did use the #int_ext interrrupt to start with. I post the code after revising it. I apologize for not posting it earlier.
#include <16F873.h>
#fuses HS, NOPROTECT, NOLVP,NOWDT,NOBROWNOUT
#use rs232(baud=4800,xmit=pin_c0,rcv=pin_c1,stream=GPS,bits=8,parity=N,errors)
#use rs232(baud=4800,xmit=pin_c6,rcv=pin_c7,stream=out,bits=8,parity=N)
byte c[75];
byte b=0;
byte x=75;
int i=0;
int j=0;
#int_ext noclear
void ext_isr()
byte intial;
intial=fgetc(GPS);
if(intial=='$')
c[i]=fgetc(GPS);
i=i+1;
if(i==x)
i=0;
byte getdata()
byte data;
data=c[j];
j=j+1;
if(j==x)
j=0;
return data;
enable_interrupts(int_ext);
while(true)
fputc(getdata(),out);
The output still remains a garbage. I understand, as you said that there is a timing issue involved in the interrupt routine. But I am not able to get rid of it.
Thanks once again. |
Posted: Thu May 18, 2006 6:04 pm |
I should have said that the INT_EXT interrupt is only available on
pin B0 in the 16F873. It's not available on pin C0. |
rnielsen
Posted: Fri May 19, 2006 8:44 am |
First, make sure your setup() commands are Not inside your while(1) loop. You are forcing the processor to set everything up each loop. Have your while(1) loop Below all of these.
I've made commercial devices, using GPS receivers, and I STRONGLY suggest you use the hardware RX pin for this. You do Not want to lose any data from your receiver. If there is ANY possible way to change to the hardware, do it! If you need a second serial port to send data out then use that one as a software port.
Ronald |
Posted: Mon May 22, 2006 9:37 am |
Thankyou PCM programmer and Ronald.
Is there any way I could communicate keeping C0 and C1 as my Tx and Rx pins?
I tried to communicate with the receiver without using any interrrupt functions, but to no avail.
I understand what Ronlad said, but I don't think I can change the pins right now.
Please let me know how to tackle the issue.
Thanks. |
