How can i rotating the values of an an array
The Puma
PostPosted: Sat May 20, 2006 9:22 am     Reply with quote
This is the array
How can i move the array values one position down
Here is how the array is build
There are 10 dot matrix displays
Each dot matrix has 5 bytes
as example: dot matrix 10 =
message[0] --> 1. column of the dot matrix (left side of display)
message[1] --> 2. column
message[2] --> 3. column
message[3] --> 4. column
message[4] --> 5. column (right side of display)
  Address      Symbol Name           Value
    0005    message
    0005    [0]                               0x7F
    0006    [1]                               0x49
    0007    [2]                               0x49
    0008    [3]                               0x49
    0009    [4]                               0x36
    000A    [5]                               0x00
    000B    [6]                               0x00
    000C    [7]                               0x00
    000D    [8]                               0x00
    000E    [9]                               0x00
    000F    [10]                              0x00
    0010    [11]                              0x00
    0011    [12]                              0x00
    0012    [13]                              0x00
    0013    [14]                              0x00
    0014    [15]                              0x00
    0015    [16]                              0x00
    0016    [17]                              0x00
    0017    [18]                              0x00
    0018    [19]                              0x00
    0019    [20]                              0x00
    001A    [21]                              0x00
    001B    [22]                              0x00
    001C    [23]                              0x00
    001D    [24]                              0x00
    001E    [25]                              0x00
    001F    [26]                              0x00
    0020    [27]                              0x00
    0021    [28]                              0x00
    0022    [29]                              0x00
    0023    [30]                              0x00
    0024    [31]                              0x00
    0025    [32]                              0x00
    0026    [33]                              0x00
    0027    [34]                              0x00
    0028    [35]                              0x00
    0029    [36]                              0x00
    002A    [37]                              0x00
    002B    [38]                              0x00
    002C    [39]                              0x00
    002D    [40]                              0x00
    002E    [41]                              0x00
    002F    [42]                              0x00
    0030    [43]                              0x00
    0031    [44]                              0x00
    0032    [45]                              0x00
    0033    [46]                              0x00
    0034    [47]                              0x00
    0035    [48]                              0x00
    0036    [49]                              0x00
luckyluke
PostPosted: Sat May 20, 2006 11:04 am     Reply with quote
for (i=0;i<50;i++){
temp[i]=message[i];
for (i=0;i<50;i++){
message[i+1]=temp[i];
if(i==49)
message[49]=temp[0];
tsupuntu
PostPosted: Sat May 20, 2006 12:18 pm     Reply with quote
for (i=0;i<50;i++){
if(i==0) temp=message[i];
if(i<49) message[i]=message[i+1];
if(i==49) message[i]=temp;
} ///// this method save ram because not array temp
PostPosted: Sat May 20, 2006 3:39 pm     Reply with quote
Realistically though, don't...
Look at how circular buffers work. It is far more efficient to move your access 'point', than to move the whole array.
The Puma
PostPosted: Sun May 21, 2006 3:47 am     Reply with quote
The array must move this way.
message[4] moves to message[3] / dot matrix 10
message[3] moves to message[2]
message[2] moves to message[1]
message[1] moves to message[0]
message[0] moves to message[9]
message[9] moves to message[8] / dot matrix 9
message[8] moves to message[7]
message[7] moves to message[6]
message[6] moves to message[5]
message[5] moves to message[14]
and so until dot matrix 1 is reached
PostPosted: Sun May 21, 2006 4:15 am     Reply with quote
Why????
The point is, that if you implement a circular buffer, the data will address as if it moves, but no physical movement need take place. This is how serial I/O buffers are implemented, and is hundreds of times more efficient in terms of processor work. It is like the difference between using a wheel, and trying to move stuff on bit of board. Once the wheel is invented, nobody would bother to use the board if they don't have to...
#define read_byte(x,y) message[(x+y) % sizeof(message))]
Then just have a variable 'offset'. Start with this as '0', and
'read_byte(0,offset)', will return message[0]. Increment it to '1', and 'read_byte(0,offset), will return message[1], and so on. The message never has to move, but your access to it shifts, as if it has moved.
The Puma
PostPosted: Sun May 21, 2006 4:25 am     Reply with quote
I did't understand it
but this is the display code.
It shows first the left most column (=C1) of each dot matrix display
and then the next column, until of five colums are proceded
void max7221_display_message() {
   int column,matrix,index;
   for(column=DIGIT_0;column<=DIGIT_4;column++) {
      index=column-1;
      output_low(MAX7221_CS);
      for(matrix=DOT_MATRIX_DISPLAY_LEFT;matrix<=DOT_MATRIX_DISPLAY_RIGHT;matrix++) {
         spi_write(column);
         spi_write(message[index]);
         index+=5;
      output_high(MAX7221_CS);
How can i move now the letter "B" in this example one column to right?
For the movement the array buffer is filled so:
message[0]=0x7f = column C1
message[1]=0x49 = column C2
message[2]=0x49 = column C3
message[3]=0x49 = column C4
message[4]=0x36 = column C5
after the letter "B" is moved one column position to rigth the array buffer must be so to display it correct on the dot matrix displays
message[9]=0x7f = column C5 of next dot matrix display
message[0]=0x49
message[1]=0x49
message[2]=0x49
message[3]=0x36
PostPosted: Sun May 21, 2006 5:27 am     Reply with quote
Use the 'read_byte' define I posted, where you currently read from the array. Have a variable containing the 'offset' you want in the array. Then if you want to move forward by one column, increment this. If you want to move forward by five columns, add 5 to it.
Imagine the array is like this (a smaller version to save my typing...):
M[0] = 0
M[1] = 1
M[2] = 2
M[3] = 3
M[4] = 4
M[5] = 5
M[6] = 6
M[7] = 7
M[8] = 8
M[9] = 9
and the array is just ten elements long as shown (hence 'sizeof(M]', will return ten).
Now if you have a counter, and access the array, from element 0 to 9, you retrieve 0,1,2.......9
If though you now use the code I show (but modified since I couldn't be bothered to type 'message' ten times!), as:
#define read_byte(x,y) M[(x+y) % sizeof(M))]
and retrieve the values with:
read_byte(counter,offset),
Then if offset=0, the behaviour will be exactly 'normal'. However now add 1 to 'offset'. Read_byte(0,offset), now retrieves element 1 (since 1+0=1). However the key is that when you use read_byte(9,offset), you get element 0!. What happens, is that 9+1=10. The array is ten elements long, and the '%' operator, gives the remainder when you divide by this. 10/10, has a remainder of 0, so you access element 0.
So calling read_byte(counter,offset), with offset = 1, gives :
1,2,3,4,5,6,7,8,9,0
Just as if the array had moved by one address.
If you change offset to 3 (say), you get:
3,4,5,6,7,8,9,0,1,2
Just as if the array had moved by 3.
Effectively, 'offset' gives where in the array you will start reading. So if you move offset forward by the amount you want to move through the array, you will access the array, as if it's start 'point', is offset by this amount. The data never has to move, you just change where you start looking at i!.
tsupuntu
PostPosted: Mon May 22, 2006 3:45 pm     Reply with quote
tsupuntu wrote:
for (i=0;i<50;i++){
reverse ways
for(i=49;i>=0;i--){
if(i==49)temp=message[i];
if(i<49 && i>0)mess[i]=message[i-1];
if(i==0)message[i]=temp;
