The Puma
Joined: 23 Apr 2004 Posts: 227 Location: The Netherlands
| How move a byte one byte to left in this array |
Posted: Sun May 07, 2006 3:37 pm |
How can i move the five bytes at position 45 one byte each other to left
The five bytes make the letter A
It is used for making a routeting message on the dot matrix displays
I need a efficient routine to do this
const char message[50] = {
0x00, 0x00, 0x00, 0x00, 0x00, // 0
0x00, 0x00, 0x00, 0x00, 0x00, // 5
0x00, 0x00, 0x00, 0x00, 0x00, // 10
0x00, 0x00, 0x00, 0x00, 0x00, // 15
0x00, 0x00, 0x00, 0x00, 0x00, // 20
0x00, 0x00, 0x00, 0x00, 0x00, // 25
0x00, 0x00, 0x00, 0x00, 0x00, // 30
0x00, 0x00, 0x00, 0x00, 0x00, // 35
0x00, 0x00, 0x00, 0x00, 0x00, // 40
0x7E, 0x7E, 0x11, 0x11, 0x7E // 45
After the move it must be this
0x00, 0x00, 0x00, 0x00, 0x7E, // 40
0x11, 0x11, 0x11, 0x7E, 0x00 // 45
Each five bytes displayed on ten 5x7 ot matrix displays
This array is the displaybuffer. |
Posted: Sun May 07, 2006 3:41 pm |
You can't.
Since this is a constant array, you cannot move the data at all.
However may I suggest a possible 'route'. If you have the address you want to 'start' reading from the array as 'address', and the _offset_ (how much you want to move the data), in a signed variable called 'offset', then:
message[(address+offset)%50]
will access the array as if it started 'offset' bytes from where it really does. You can increment, and decrement 'offset', to move where you access the array from.
andreluizeng
Posted: Mon May 08, 2006 6:32 am |
you can do this if you use a pointer to that array.
for example:
void MoveByte (char **Array, int Positions)
char AuxArray[50];
int i;
int j;
for (i = 0; i < 50; i++)
AuxArray[i] = (* Array)[i]; // copy the orignal values
for (i = 0, j = Positions; i < 50; i++)
(*Array)[i] = AuxArray[Positions];
Positions++;
// last position of an array is a null terminated
if (Positions > 49)
Positions = 0;
return;
// and you call this function in main, like this:
void main ()
MoveByte (&Message, 4); // it will probably move 4 bytes
return;
if you get some problem, write again.
regards _________________ Andre |
Posted: Mon May 08, 2006 6:34 am |
You can't use pointers to constant arrays in CCS. Hence my suggestion to use an offset byte instead.
andreluizeng
Posted: Mon May 08, 2006 6:56 am |
i thought that it was possible...
if is not..
sorry.
so.. he can make it using a dinamic array...
char *message;
message = (char *) malloc (sizeof (char) * 50);
regards. _________________ Andre |
Posted: Mon May 08, 2006 7:45 am |
He doesn't even need to fiddle around like this. If the word 'const' is just removed from the declaration, the array will be a simple variable one, and the compiler will handle the initialisation as well. However the 'downside' of the variable array, is the need for 50 bytes of RAM (which may be a problem on some PICs). On smaller PICs, using the offset to the const array may be the better solution.
The Puma
Posted: Mon May 08, 2006 9:27 am |
Is there another option to do this on a simple matter
I need this to shift data on 10 dot matrix displays by one column each
Maybe another structure |
Ducky Guest
| Shift it :-) |
Posted: Wed May 17, 2006 4:31 pm |
remove the const from your array declaration....than you can use the rotate_right or rotate_left function.
for example...
rotate_left(message,50); |
Ducky Guest
| Sorry...missed somethink |
Posted: Wed May 17, 2006 4:33 pm |
rotate_x rotates only one bit
the following rotates one byte....sorry
int loop = 0;
for(loop = 0; loop < 8;loop++)
rotate_right(message,50); |
