The Puma
Joined: 23 Apr 2004 Posts: 227 Location: The Netherlands
| max array size PIC18F4620 |
Posted: Sat May 13, 2006 9:41 am |
i have this array.
It displayed the characters correct to the fontdata of the "S"
Thereafter there is only junk
Can this be a problem with the array size?
// Declare and Init the font array data
char Font[96][5] = {
0x00, 0x00, 0x00, 0x00, 0x00, // 0x20, Space
0x00, 0x00, 0x5F, 0x00, 0x00, // 0x21, !
0x00, 0x07, 0x00, 0x07, 0x00, // 0x22, "
0x14, 0x7F, 0x14, 0x7F, 0x14, // 0x23, #
0x24, 0x2A, 0x7F, 0x2A, 0x12, // 0x24, $
0x23, 0x13, 0x08, 0x64, 0x62, // 0x25, %
0x36, 0x49, 0x55, 0x22, 0x50, // 0x26, &
0x00, 0x05, 0x03, 0x00, 0x00, // 0x27, '
0x00, 0x1C, 0x22, 0x41, 0x00, // 0x28, (
0x00, 0x41, 0x22, 0x1C, 0x00, // 0x29, )
0x08, 0x2A, 0x1C, 0x2A, 0x08, // 0x2a, *
0x08, 0x08, 0x3E, 0x08, 0x08, // 0x2b, +
0x00, 0x50, 0x30, 0x00, 0x00, // 0x2c, ,
0x08, 0x08, 0x08, 0x08, 0x08, // 0x2d, -
0x00, 0x60, 0x60, 0x00, 0x00, // 0x2e, .
0x20, 0x10, 0x08, 0x04, 0x02, // 0x2f, /
0x3E, 0x51, 0x49, 0x45, 0x3E, // 0x30, 0
0x00, 0x42, 0x7F, 0x40, 0x00, // 0x31, 1
0x42, 0x61, 0x51, 0x49, 0x46, // 0x32, 2
0x21, 0x41, 0x45, 0x4B, 0x31, // 0x33, 3
0x18, 0x14, 0x12, 0x7F, 0x10, // 0x34, 4
0x27, 0x45, 0x45, 0x45, 0x39, // 0x35, 5
0x3C, 0x4A, 0x49, 0x49, 0x30, // 0x36, 6
0x01, 0x71, 0x09, 0x05, 0x03, // 0x37, 7
0x36, 0x49, 0x49, 0x49, 0x36, // 0x38, 8
0x06, 0x49, 0x49, 0x29, 0x1E, // 0x39, 9
0x00, 0x36, 0x36, 0x00, 0x00, // 0x3a, :
0x00, 0x56, 0x36, 0x00, 0x00, // 0x3b, ;
0x00, 0x08, 0x14, 0x22, 0x41, // 0x3c, <
0x14, 0x14, 0x14, 0x14, 0x14, // 0x3d, =
0x41, 0x22, 0x14, 0x08, 0x00, // 0x3e, >
0x02, 0x01, 0x51, 0x09, 0x06, // 0x3f, ?
0x32, 0x49, 0x79, 0x41, 0x3E, // 0x40, @
0x7E, 0x11, 0x11, 0x11, 0x7E, // 0x41, A
0x7F, 0x49, 0x49, 0x49, 0x36, // 0x42, B
0x3E, 0x41, 0x41, 0x41, 0x22, // 0x43, C
0x7F, 0x41, 0x41, 0x22, 0x1C, // 0x44, D
0x7F, 0x49, 0x49, 0x49, 0x41, // 0x45, E
0x7F, 0x09, 0x09, 0x01, 0x01, // 0x46, F
0x3E, 0x41, 0x41, 0x51, 0x32, // 0x37, G
0x7F, 0x08, 0x08, 0x08, 0x7F, // 0x48, H
0x00, 0x41, 0x7F, 0x41, 0x00, // 0x49, I
0x20, 0x40, 0x41, 0x3F, 0x01, // 0x4a, J
0x7F, 0x08, 0x14, 0x22, 0x41, // 0x4b, K
0x7F, 0x40, 0x40, 0x40, 0x40, // 0x4c, L
0x7F, 0x02, 0x04, 0x02, 0x7F, // 0x4d, M
0x7F, 0x04, 0x08, 0x10, 0x7F, // 0x4e, N
0x3E, 0x41, 0x41, 0x41, 0x3E, // 0x4f, O
0x7F, 0x09, 0x09, 0x09, 0x06, // 0x50, P
0x3E, 0x41, 0x51, 0x21, 0x5E, // 0x51, Q
0x7F, 0x09, 0x19, 0x29, 0x46, // 0x52, R
0x46, 0x49, 0x49, 0x49, 0x31, // 0x53, S
0x01, 0x01, 0x7F, 0x01, 0x01, // 0x54, T
0x3F, 0x40, 0x40, 0x40, 0x3F, // 0x55, U
0x1F, 0x20, 0x40, 0x20, 0x1F, // 0x56, V
0x7F, 0x20, 0x18, 0x20, 0x7F, // 0x57, W
0x63, 0x14, 0x08, 0x14, 0x63, // 0x58, X
0x03, 0x04, 0x78, 0x04, 0x03, // 0x59, Y
0x61, 0x51, 0x49, 0x45, 0x43, // 0x5a, Z
0x00, 0x00, 0x7F, 0x41, 0x41, // 0x5b, [
0x02, 0x04, 0x08, 0x10, 0x20, // 0x5c, \
0x41, 0x41, 0x7F, 0x00, 0x00, // 0x5d, ]
0x04, 0x02, 0x01, 0x02, 0x04, // 0x5e, ^
0x40, 0x40, 0x40, 0x40, 0x40, // 0x5f, _
0x00, 0x01, 0x02, 0x04, 0x00, // 0x60, `
0x20, 0x54, 0x54, 0x54, 0x78, // 0x61, a
0x7F, 0x48, 0x44, 0x44, 0x38, // 0x62, b
0x38, 0x44, 0x44, 0x44, 0x20, // 0x63, c
0x38, 0x44, 0x44, 0x48, 0x7F, // 0x64, d
0x38, 0x54, 0x54, 0x54, 0x18, // 0x65, e
0x08, 0x7E, 0x09, 0x01, 0x02, // 0x66, f
0x08, 0x14, 0x54, 0x54, 0x3C, // 0x67, g
0x7F, 0x08, 0x04, 0x04, 0x78, // 0x68, h
0x00, 0x44, 0x7D, 0x40, 0x00, // 0x69, i
0x20, 0x40, 0x44, 0x3D, 0x00, // 0x6a, j
0x00, 0x7F, 0x10, 0x28, 0x44, // 0x6b, k
0x00, 0x41, 0x7F, 0x40, 0x00, // 0x6c, l
0x7C, 0x04, 0x18, 0x04, 0x78, // 0x6d, m
0x7C, 0x08, 0x04, 0x04, 0x78, // 0x6e, n
0x38, 0x44, 0x44, 0x44, 0x38, // 0x6f, o
0x7C, 0x14, 0x14, 0x14, 0x08, // 0x70, p
0x08, 0x14, 0x14, 0x18, 0x7C, // 0x71, q
0x7C, 0x08, 0x04, 0x04, 0x08, // 0x72, r
0x48, 0x54, 0x54, 0x54, 0x20, // 0x73, s
0x04, 0x3F, 0x44, 0x40, 0x20, // 0x74, t
0x3C, 0x40, 0x40, 0x20, 0x7C, // 0x75, u
0x1C, 0x20, 0x40, 0x20, 0x1C, // 0x76, v
0x3C, 0x40, 0x30, 0x40, 0x3C, // 0x77, w
0x44, 0x28, 0x10, 0x28, 0x44, // 0x78, x
0x0C, 0x50, 0x50, 0x50, 0x3C, // 0x79, y
0x44, 0x64, 0x54, 0x4C, 0x44, // 0x7a, z
0x00, 0x08, 0x36, 0x41, 0x00, // 0x7b, {
0x00, 0x00, 0x7F, 0x00, 0x00, // 0x7c, |
0x00, 0x41, 0x36, 0x08, 0x00, // 0x7d, }
0x08, 0x08, 0x2A, 0x1C, 0x08, // 0x7e, ~
0x08, 0x1C, 0x2A, 0x08, 0x08 // 0x7f, DEL
And this is the routine to fill a string with fontdata
char *message,*text;
void max7221_fill_buffer(char *buffer) {
int txtptr;
int messptr=0;
memset(message,0x00,50);
for(txtptr=0;buffer[txtptr];txtptr++) {
strncopy(message+messptr,font+((buffer[txtptr]-0x60)*5),5);
message[messptr+5]=0;
messptr+=5;
