emh203@psu.edu
| Function Pointers? |
Posted: Fri May 05, 2006 4:01 pm |
Does CCS allow the use of function pointers? For example, I want to pass a function pointer in another function like so (standard C):
unsigned char RegisterMessageDelegate(int (*MessageDelegate)(unsigned char *,unsigned short));
The compiler will not allow this. Is there another way of using function pointers with this compiler?
Thanks,
ELi |
treitmey
emh203@psu.edu
| No, not pointers to variables, pointers to Function |
Posted: Mon May 08, 2006 7:26 am |
QSORT Only appears to be a standard pointer (for memory/variables). What I need is support for pointers to Functions.
-ELi |
Posted: Mon May 08, 2006 7:38 am |
No, QSORT, uses pointers to functions, not just to values. There is a function 'ascending', and a function 'descending', and these are passed to the qsort function as the 'compare' item. Look again.
Mark
Posted: Mon May 08, 2006 7:59 am |
You can also use the search feature to find your answers. Here is a snippet from an old post
// Typedef for our function pointer
typedef int (*pFunc)(void);
int myfunction(void)
return (1);
int i;
pFunc ptrtofunc;
// Dummy initialization to keep the compiler from complaining
ptrtofunc = myfunction;
// Call the function
i=(*ptrtofunc)();
while( TRUE )
