oscarec60
Joined: 23 Mar 2006 Posts: 3 Location: Caracas, Venezuela
| For favo I need urgent help with EEPROM of the pic18f4620 I |
Posted: Wed Apr 26, 2006 7:41 am |
The proble is the following one, I want that in EEPROM it records me the data that he/she sends me the such keyboard and like it is shown in the code, and then he/she sent them for parallelly for the port TO but for some reason this doesn't make it.
#include <18F4620.h>
#device adc=8
#fuses NOWDT,WDT128,HS, NOPROTECT, IESO, BROWNOUT, BORV21, NOPUT, NOCPD, NOSTVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, NOFCMEN, NOXINST, NOPBADEN, NOLPT1OSC, NOMCLR
//#define set_tris_d
//#device adc=8
//#use delay(clock=8000000)
//#fuses NOWDT,WDT128,INTRC_IO, NOPROTECT, IESO, BROWNOUT, BORV21, NOPUT, NOCPD, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, NOFCMEN, NOXINST, NOPBADEN, NOLPT1OSC, NOMCLR
#zero_ram
//#define output_d
#define LCD_DB4 PIN_C4
#define LCD_DB5 PIN_C5
#define LCD_DB6 PIN_C6
#define LCD_DB7 PIN_C7
#define LCD_RS PIN_C0
#define LCD_RW PIN_C1
#define LCD_E PIN_C2
#include <flex_lcd.c>
// Definiciones globales
unsigned char edge, bitcount;
char got_interrupt;
char interrupt_count;
char status_b7;
#bit INTF_BIT = 0x0B.1
//-------- Tabla de caracteres correspondientes a la pulsación de la tecla
//-------- en modalidad normal (sin pulsar SHIFT)
unsigned char const unshifted[68][3] = {
0x0d,9,0x00,
0x0e,'º',0x00,
0x15,'q',0x37,
0x16,'1',0x07,
0x1a,'z',0x1d,
0x1b,'s',0x26,
0x1c,'a',0x01,
0x1d,'w',0x3a,
0x1e,'2',0x03,
0x21,'c',0x21,
0x22,'x',0x2d,
0x23,'d',0x31,
0x24,'e',0x11,
0x25,'4',0x31,
0x26,'3',0x21,
0x29,' ',0x00,
0x2a,'v',0x0f,
0x2b,'f',0x23,
0x2c,'t',0x36,
0x2d,'r',0x17,
0x2e,'5',0x11,
0x31,'n',0x35,
0x32,'b',0x03,
0x33,'h',0x13,
0x34,'g',0x33,
0x35,'y',0x3d,
0x36,'6',0x23,
0x39,',',0x02,
0x3a,'m',0x25,
0x3b,'j',0x32,
0x3c,'u',0x0d,
0x3d,'7',0x33,
0x3e,'8',0x13,
0x41,',',0x02,
0x42,'k',0x05,
0x43,'i',0x22,
0x44,'o',0x15,
0x45,'0',0x32,
0x46,'9',0x22,
0x49,'.',0x04,
0x4a,'-',0x0c,
0x4b,'l',0x01,
0x4c,'ñ',0x3b,
0x4d,'p',0x27,
0x4e,''',0x00,
0x52,'´',0x00,
0x54,'`',0x00,
0x55,'¡',0x16,
0x5a,13,0x00,
0x5b,'+',0x00,
0x5d,'ç',0x00,
0x61,'<',0x00,
0x66,8,0x00,
0x69,'1',0x01,
0x6b,'4',0x31,
0x6c,'7',0x33,
0x70,'0',0x32,
0x71,'.',0x04,
0x72,'2',0x03,
0x73,'5',0x11,
0x74,'6',0x23,
0x75,'8',0x13,
0x79,'+',0x00,
0x7a,'3',0x21,
0x7b,'-',0x0c,
0x7c,'*',0x00,
0x7d,'9',0x22,
0,0,0
//-------- en modalidad desplazamiento (pulsando SHIFT)
unsigned char const shifted[68][3] = {
0x0d,9,0x00,
0x0e,'ª',0x00,
0x15,'Q',0x37,
0x16,'!',0x16,
0x1a,'Z',0x1d,
0x1b,'S',0x26,
0x1c,'A',0x01
0x1d,'W',0x3a,
0x1e,'"',0x0e,
0x21,'C',0x21,
0x22,'X',0x2d,
0x23,'D',0x31,
0x24,'E',0x11,
0x25,'$',0x00,
0x26,'·',0x00,
0x29,' ',0x00,
0x2a,'V',0x0f,
0x2b,'F',0x23,
0x2c,'T',0x36,
0x2d,'R',0x17,
0x2e,'%',0x00,
0x31,'N',0x35,
0x32,'B',0x03,
0x33,'H',0x13,
0x34,'G',0x33,
0x35,'Y',0x3d,
0x36,'&',0x00,
0x39,'L',0x07,
0x3a,'M',0x25,
0x3b,'J',0x32,
0x3c,'U',0x0d,
0x3d,'/',0x00,
0x3e,'(',0x1b,
0x41,';',0x06,
0x42,'K',0x05,
0x43,'I',0x22,
0x44,'O',0x15,
0x45,'=',0x00,
0x46,')',0x34,
0x49,':',0x12,
0x4a,'_',0x00,
0x4b,'L',0x07,
0x4c,'Ñ',0x3b,
0x4d,'P',0x27,
0x4e,'?',0x0a,
0x52,'¨',0x00,
0x54,'^',0x00,
0x55,'¿',0x0a,
0x5a,13,0x00,
0x5b,'*',0x00,
0x5d,'Ç',0x00,
0x61,'>',0x00,
0x66,8,0x00,
0x69,'1',0x01,
0x6b,'4',0x31,
0x6c,'7',0x33,
0x70,'0',0x32,
0x71,'.',0x04,
0x72,'2',0x03,
0x73,'5',0x11,
0x74,'6',0x23,
0x75,'8',0x13,
0x79,'+',0x00,
0x7a,'3',0x21,
0x7b,'-',0x00,
0x7c,'*',0x00,
0x7d,'9',0x22,
0,0,0
//-------- Tabla de caracteres traducido a Braille
//-------- para caracteres cuando ya ha sido pulsado el SHIFT y le corresponde primero el caracter de mayuscula en Braille
// Definición de protipos
void init_kb(void);
void decode(unsigned char sc);
#int_ext
void int_ext_isr(void);
// Main
int j;
j=0;
//setup_adc_ports(AN0|VSS_VDD);
//setup_adc(ADC_CLOCK_INTERNAL);
setup_adc(ADC_OFF);
// setup_psp(PSP_ENABLED);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
// set_adc_channel( 0 ); //RA0 como entrada
// delay_us(100);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
lcd_init();
init_kb();
//lcd_gotoxy(0x00,0x00);
//printf(lcd_putc," \n ");
//-------- Los pins indicados (B0 y B7) son configurados como entradas.
output_float(PIN_B0);
output_float(PIN_B7);
//-------- Activa pullups sobre todos los pins del puerto B.
port_b_pullups(TRUE);
//-------- Espera a que se activen.
delay_us(5);
//-------- Inicializa las variables usadas por la rutina de interrupción
//-------- antes de activar las interrupciones
interrupt_count = 0;
got_interrupt = FALSE;
status_b7 = 0;
//-------- Desde que se activó el modo PULLUPS del puerto B, el estado
//-------- normal del pin B0 es ALTO. La gestión de la interrupción externa
//-------- se gestiona cuando se produce un cambio de nivel ALTO a BAJO.
ext_int_edge(H_TO_L);
//-------- Asegurarse de que el el bit de flag de la interrupción externa
//-------- es borrado antes de activar la gestión de dicha interrupción
//-------- externa.
INTF_BIT = 0;
enable_interrupts(INT_EXT);
//-------- Bucle principal.
//-------- Chequear si se produce alguna interrupción (got_interrupt). Si es así, contar, borrar
//-------- el flag y esperar 50 ms, reactivando la gestión de las interrupciones
if(got_interrupt == TRUE)
//-------- Borrar el flag global que se inicio en la rutina de servicio
//-------- de interrupciones externas.
//-------- Esperar 50 ms para evitar rebotes en los contactos de las teclas.
//delay_ms(50);
//-------- Borrar cualquier interrupción producida durante el periodo de espera.
INTF_BIT = 0;
//-------- Reactivar interrupciones
} // --- End If ---
} // --- End While ---
} // --- End MAIN ---
// Funciones
// Inicialización de teclado.
void init_kb(void)
//-------- Longitud de la trama para cada pulsación y mensaje de bienvenida
bitcount = 11;
printf(lcd_putc,"Dispositivo para\n Sordo-Ciegos ");
// Decodificación de pulsaciones
static unsigned char is_up=0, shift = 0, mode = 0;
unsigned char i;
unsigned char x=0;
//-------- El último dato recibido fue el identificador de Up-Key
if (!is_up)
switch (sc)
//-------- Identificador de Up-Key
case 0xF0 :
is_up = 1;
//-------- SHIFT Izquierdo
case 0x12 :
shift = 1;
//-------- SHIFT Derecho
case 0x59 :
shift = 1;
//-------- ENTER
case 0x5A :
shift = 0;
for(i=0; i == j ;i++)
output_a(read_eeprom(i));
output_a(0x00);
i++;
if(j<16 && x == 0)
printf(lcd_putc,"\n");
j=0;
x=1;
// lcd_gotoxy(0x00,0x00);
j=0;
x=0;
//-------- Si no es ninguno de los identificadores especiales, procesar
//-------- pulsación, localizando caracter en tabla de caracteres.
default:
//-------- Pulsación normal
if(!shift)
for(i = 0; unshifted[i][0]!=sc && unshifted[i][0]; i++);
printf(lcd_putc,"%c", unshifted[i][1]);
if(sc == 0x66)
j--;
write_eeprom(j,unshifted[i][2]);
j++;
//-------- Pulsación + SHIFT presionado
for(i = 0; shifted[i][0]!=sc && shifted[i][0]; i++);
if (shifted[i][0] == sc)
printf(lcd_putc,"%c", shifted[i][1]);
write_eeprom(j,0x28);
j++;
write_eeprom(j,0x00);
j++;
write_eeprom(j,shifted[i][2]);
j++;
} // --- End Switch
//-------- No se permiten 2 0xF0 en una fila
is_up = 0;
switch (sc)
case 0x12 :
shift = 0;
case 0x59 :
shift = 0;
} // --- End Switch
// Rutina de gestión de interrupciones
#int_ext
unsigned char data;
//-------- Los bit 3 a 10 se considerran datos. Paridad, start y stop
//-------- son ignorados
if(bitcount < 11 && bitcount > 2)
data = (data >> 1);
status_b7 = input(PIN_B7);
if((status_b7) == 1)
data = data | 0x80;
//-------- Todos los bits se han recibido
if(--bitcount == 0)
decode(data);
data = 0;
bitcount = 11;
got_interrupt = TRUE;
interrupt_count++;
disable_interrupts(INT_EXT);
