| View previous topic :: View next topic   |
			javi.ar
				| ADC 12F683 |
				 Posted: Fri Mar 31, 2006 11:22 am     |
				Hello everybody:
IŽm using a 12f683 and reading ADC from a LM35, but the reading is always the same no matter what I read (GND or VCC) , I used all 3 AD inputs and set all analog. No success so far , I am using CCS 3.23 .
Thanks in advance to everybody. |
				 Posted: Fri Mar 31, 2006 1:25 pm     |
				 	  | Quote: | 	 		  | I am using CCS 3.23  |
Post your complete compiler version.   The version has 3 digits after
the decimal point.   The version is given at the top of the .LST file.
You can find that file in your project folder. |
			javi.ar
				 Posted: Fri Mar 31, 2006 2:08 pm     |
				Sorry Version is 3.235
I use read_adc() for reading ADC output. |
				 Posted: Fri Mar 31, 2006 2:57 pm     |
				I don't see any problems with the A/D code or the CCS setup code
for your version of the compiler.  So you need to post a test program.
Make it be complete but short. (like 20 lines, total). |
			javi.ar
				 Posted: Fri Mar 31, 2006 9:27 pm     |
				Here is all the code...
#include <12F683.h>
#include <ini12F683.h>
#device adc=8
#FUSES NOWDT                 	//No Watch Dog Timer
#FUSES INTRC_IO
#FUSES NOCPD                 	//No EE protection
#FUSES NOPROTECT             	//Code not protected from reading
#FUSES MCLR                  	//Master Clear pin enabled
#FUSES PUT                 	//Power Up Timer
#FUSES NOBROWNOUT            	//No brownout reset
#FUSES IESO                  	//Internal External Switch Over mode enabled
#FUSES FCMEN                 	//Fail-safe clock monitor enabled
//#bit led = GPIO.2
#bit ledr = GPIO.5
#use rs232(baud=9600,parity=N,xmit=PIN_A4,bits=8)
data ()
int dato;
   while (1)
   dato = read_adc();
   printf ("valor %2X ", dato);
   if (dato < 0)
      ledr = 1;
   setup_adc_ports(sAN2|VSS_VDD);
   set_adc_channel(0);
   delay_us(100);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   setup_oscillator(OSC_4MHZ);
      //Funciones Personales
GPIO= 0b000000; TRISIO= 0b001100;
ledr = 1 ;
data ();
Thanks guys a lot... |
				 Posted: Sat Apr 01, 2006 1:25 am     |
				One obvious problem is that you have configured the A/D port so that
pin AN2 is the analog input pin, but then you have selected channel 0
for the A/D conversion.    They have to be the same.   You need to
change it so that both lines are setup for channel 0, or both for channel 2.
 	  | Quote: |
set_adc_channel(0);
			javi.ar
				 Posted: Tue Apr 04, 2006 7:47 pm     |
				 	  | PCM programmer wrote: | 	 		  One obvious problem is that you have configured the A/D port so that
 	  | Quote: |
set_adc_channel(0);
I have done all modifications, but still reading 0x03 no matter what I place in input pin, 0v or Vcc (5v) any other hint, please.
I also switch the PIC for a brand new one, also same output value...
Thanks to all of you... great to be in a forum like this one.. |
			Humberto
				 Posted: Tue Apr 04, 2006 10:11 pm     |
				You defined the variable dato as an unsigned integer, its permissible range is 0-255.
Will never get true.
Take away this line, let the compiler to do his job, or at least set the bits accordingly.
Ie: as show, bit 0 is an output, but you are trying to read from the analog input channel 0.
 	  | Quote: |
Define the analog inputs that you are going to use:
setup_adc_ports(sAN0|sAN1|sAN2|sAN3|VSS_VDD);
set_adc_channel(1); // Select the channel you want to read:
while (1)
    dato = read_adc();
    printf("A/D value = %2x\n\r", dato);
Humberto |
			javi.ar
				 Posted: Wed Apr 05, 2006 6:28 am     |
				Thanks Humberto... very kind ...
IŽll try it later, and let everybody know if it worked...
Saludos (Soy de Buenos Aires) |
			javi.ar
				 Posted: Thu Apr 20, 2006 8:00 pm     |
				 	  | javi.ar wrote: | 	 		  Thanks Humberto... very kind ...
Finally I made it, with your help...
set_adc_channel(2) ;
instead of
set_adc_channel(sAN2) ;
I worked!!!! Great, so  thank you all... |
