period of 100 us
aymen
period of 100 us
PostPosted: Thu Apr 27, 2006 6:10 am     Reply with quote
I want to fix a period of 100us (T=100us),which i use in my calculation.I have a problem to find it.
i look for your help.
Mark
PostPosted: Thu Apr 27, 2006 6:26 am     Reply with quote
We have a problem understanding what you want to do! Are you wanting a timer to give an int every 100us? That is pretty fast if your pic is running slow. What pic and freq do you have?
aymen
PostPosted: Thu Apr 27, 2006 7:16 am     Reply with quote
pic is 18f442 with freq of 40MHZ.
i want to introduce a value of 100 us .
this solution is possible?
float T
#int_timer1 noclear
clock_isr(){
T=get_timer1();
main()
for(;;)
enable_interrupts(global);
set_timer1(65411); // 65536-65411=125 coresspond for T= 100 us /// (100/0.8)=125
setup_timer_1(T1_internal| T1_div_by_8); // th timer overflow every 0.8 us
Mark
PostPosted: Thu Apr 27, 2006 9:01 am     Reply with quote
I am using a 18F6720 @ 40MHz to sample a DALI bus every 104us. So the answer is yes. I use a CCP interrupt however. I set the CCP to reset the timer so that I do not have problems with latency "adding up".
Note that you have noclear flag and are not clearing the int. Not a good thing. Also, get_timer1 should return a 16 bit int and not a float.
