jjude Guest
| ADC problem |
Posted: Fri Mar 31, 2006 11:13 am |
ADC-results is 8-bit!?! I need 10-bit!
Code (i load code PIC16F876A bootloader):
#case
#include <16F876A.h>
#include <ctype.h>
#device *=16
#device adc=10
#org 0x1F00, 0x1FFF {} //BootLoader 8k 16F876/7
#use delay(clock=10000000)
#fuses NOWDT,HS, PUT, NOPROTECT, NODEBUG, BROWNOUT, NOLVP, NOCPD, NOWRT
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
setup_adc_ports(ALL_ANALOG);
int16 int16count;
set_adc_channel(0);
delay_us(100);
int16count=read_adc();
Results is 1,66 volt -> 85.
What is wrong? |
Posted: Fri Mar 31, 2006 1:23 pm |
You didn't show a complete test program so I have to guess what the problem is.
My guess is that you are using only the 8-bit format specifier for printf,
and you need to use 16-bit.
Example:
You are probably doing this:
| Quote: | | printf("%x", int16count); |
You should do this:
| Quote: | | printf("%lx", int16count); |
Note the lower case "L" in front of the x. This tells the compiler
to display a 16-bit value. |
jjude Guest
| Print |
Posted: Sat Apr 01, 2006 1:34 am |
I print print("%lu",int32count);
I test adc=16. This send results 0x1ff0
adc=10 results is 0x0ff?!?!? |
Posted: Sat Apr 01, 2006 2:05 am |
Post your compiler version. This is a number such as 3.191 or 3.245,
and you can find it at the top of the .LST file. The .LST file is generated
each time you compile a program. Look for that file in your project
folder.
If you post your compiler version, I can check if there is a problem
with the A/D converter functions in your version. |
