TIMER1
TIMER1
PostPosted: Thu Mar 30, 2006 9:29 am     Reply with quote
Anyone know code for measuring a pulse from a 555 timer?
Any help would be much appreciated?
Below is the code i have at the minute. I am using PIC 16F874 and programming in C. I intend to use Port c bit 0 as my input and use timer 1 to count when it receives an high input
#include <16f874.h>
#use delay (clock = 4000000)
#byte PORTC = 7
#bit INPUT = PORTC.0
setup_timer_1(T1_INTERNAL , T1_DIV_BY_1);
long int PERIOD;
main()
set_tris_c (0x01); // setting up ports
PERIOD= 0;
while(INPUT==0)
set_timer1(0);
while(INPUT==1);
PERIOD = get_timer1();
PostPosted: Thu Mar 30, 2006 1:06 pm     Reply with quote
Look at the CCS example file: EX_CCPMP.C
The file is in this folder: c:\Program Files\Picc\Examples
