I2C with 20MHz Processor
Roger Eberle
PostPosted: Fri Mar 07, 2003 3:08 pm     Reply with quote
I've got a little problem with my I2C. On my prototype i've used an 16C76 clocked with 5MHz and an 24LC64. No Problem at all. After positiv tests, i increased the Osc-Frequency to 20MHz and compiled my c-Programm new, with the actual Freq. Result: No communication with my EEPROM. The EEPROM is ok, because if I decrease the frequency to 5MHz anything works well.
Has somebody expirience with I2C on 20MHz-prozessors?
Original Post ID: 12464
Re: I2C with 20MHz Processor
PostPosted: Fri Mar 07, 2003 3:27 pm     Reply with quote
:=I've got a little problem with my I2C. On my prototype i've used an 16C76 clocked with 5MHz and an 24LC64. No Problem at all. After positiv tests, i increased the Osc-Frequency to 20MHz and compiled my c-Programm new, with the actual Freq. Result: No communication with my EEPROM. The EEPROM is ok, because if I decrease the frequency to 5MHz anything works well.
:=Has somebody expirience with I2C on 20MHz-prozessors?
1. Did you change the #use delay statement when you changed
the crystal ? Example:
#use Delay(clock=5000000)
#use Delay(clock=20000000)
2. Are you using software or hardware i2c ? I don't think
hardware i2c works properly on the 16C77. I think it
only works on PICs that have a "MSSP" (16F877), and not
a "BSSP" which the 16C77 has.
3. What version of the compiler are you using ?
4. Are you testing this on a real chip, or are you using
ICE or simulation ?
Original Post ID: 12467
