Tre
| USB Descriptors for Composite Devices |
Posted: Tue Mar 28, 2006 10:06 pm |
I am trying to create a USB descriptor for a composite device. (www.zero-soft.com/HW/USB_NES when the hosting is actually working)
However, I am having a slight problem with the strings. I have defined all of my strings in the descriptor and I use the index of the strings I want to display in the interface descriptor for each of the two endpoints. During enumeration the correct names show up in the yellow balloons that windows has. However, when I go in and look at the devices in the control panel they both have the name of interface 1 (in this case "Controller A").
Anyone see anything that I am missing? Thanks!
PS: Sorry I can't figure out how to attach this, I guess i'll just have to paste it :<
| Code: | #IFNDEF __USB_DESCRIPTORS__
#DEFINE __USB_DESCRIPTORS__
#include <usb.h>
/// HID Report. Tells HID driver how to handle and deal with
/// received data. HID Reports can be extremely complex,
/// see HID specifcation for help on writing your own.
/// First it defines a block for the first interface for a mouse
/// protocol. Second it defines a block for the second interface
/// for a keyboard protocol.
const char USB_CLASS_SPECIFIC_DESC[] = {
// HID Descriptor for Interface 0 (Controller A)
0x05, 0x01, // USAGE_PAGE (Generic Desktop) // 0,1
0x09, 0x04, // USAGE (Joystick) // 2,3
0xa1, 0x01, // COLLECTION (Application) // 4,5
0x09, 0x01, // USAGE (Pointer) // 6,7
0xa1, 0x00, // COLLECTION (Physical) // 8,9
0x09, 0x30, // USAGE (X) // 10,11
0x09, 0x31, // USAGE (Y) // 12, 13
0x15, 0x81, // LOGICAL_MINIMUM (-127) // 14, 15
0x25, 0x7f, // LOGICAL_MAXIMUM (127) // 16, 17
0x75, 0x08, // REPORT_SIZE (8) // 18, 19
0x95, 0x02, // REPORT_COUNT (2) // 20, 21
0x81, 0x02, // INPUT (Data,Var,Abs) // 22, 23
0x05, 0x09, // USAGE_PAGE (Button) // 24, 25
0x19, 0x01, // USAGE_MINIMUM (Button 1) // 26, 27
0x29, 0x08, // USAGE_MAXIMUM (Button 8) // 28, 29
0x15, 0x00, // LOGICAL_MINIMUM (0) // 30, 31
0x25, 0x01, // LOGICAL_MAXIMUM (1) // 32, 33
0x75, 0x01, // REPORT_SIZE (1) // 34, 35
0x95, 0x08, // REPORT_COUNT (8) // 36, 37
0x81, 0x02, // INPUT (Data,Var,Abs) // 38, 39
0xc0, // END_COLLECTION // 40
0xc0 // END_COLLECTION // 41
// HID Descriptor for Interface 1 (Controller B)
0x05, 0x01, // USAGE_PAGE (Generic Desktop) // 42, 43
0x09, 0x04, // USAGE (Joystick) // 44, 45
0xa1, 0x01, // COLLECTION (Application) // 46, 47
0x09, 0x01, // USAGE (Pointer) // 48, 49
0xa1, 0x00, // COLLECTION (Physical) // 50, 51
0x09, 0x30, // USAGE (X) // 52, 53
0x09, 0x31, // USAGE (Y) // 54, 55
0x15, 0x81, // LOGICAL_MINIMUM (-127) // 56, 57
0x25, 0x7f, // LOGICAL_MAXIMUM (127) // 58, 59
0x75, 0x08, // REPORT_SIZE (8) // 60, 61
0x95, 0x02, // REPORT_COUNT (2) // 62, 63
0x81, 0x02, // INPUT (Data,Var,Abs) // 64, 65
0x05, 0x09, // USAGE_PAGE (Button) // 66, 67
0x19, 0x01, // USAGE_MINIMUM (Button 1) // 68, 69
0x29, 0x08, // USAGE_MAXIMUM (Button 8) // 70, 71
0x15, 0x00, // LOGICAL_MINIMUM (0) // 72, 73
0x25, 0x01, // LOGICAL_MAXIMUM (1) // 74, 75
0x75, 0x01, // REPORT_SIZE (1) // 76, 77
0x95, 0x08, // REPORT_COUNT (8) // 78, 79
0x81, 0x02, // INPUT (Data,Var,Abs) // 80, 81
0xc0, // END_COLLECTION // 82
0xc0 // END_COLLECTION // 83
//if a class has an extra descriptor not part of the config descriptor,
// this lookup table defines where to look for it in the const
// USB_CLASS_SPECIFIC_DESC[] array.
//first element is the config number (if your device has more than one config)
//second element is which interface number
//set element to 0xFFFF if this config/interface combo doesn't exist
const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP[USB_NUM_CONFIGURATIONS][2] =
//config 1
//interface 0
0,
//interface 1
42
// this lookup table defines the size of that descriptor.
const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[USB_NUM_CONFIGURATIONS][2] =
//config 1
//interface 0
42,
//interface 1
42
/// start config descriptor
/// right now we only support one configuration descriptor.
/// the config, interface, class, and endpoint goes into this array.
#DEFINE USB_TOTAL_CONFIG_LEN 59 //config+interface+class+endpoint
const char USB_CONFIG_DESC[] = {
//IN ORDER TO COMPLY WITH WINDOWS HOSTS, THE ORDER OF THIS ARRAY MUST BE:
// config(s)
// interface(s)
// class(es)
// endpoint(s)
//config_descriptor for config index 1
USB_DESC_CONFIG_LEN, //length of descriptor size ==0
USB_DESC_CONFIG_TYPE, //constant CONFIGURATION (CONFIGURATION 0x02) ==1
USB_TOTAL_CONFIG_LEN,0, //size of all data returned for this config ==2,3
2, //number of interfaces this device supports ==4
0x01, //identifier for this configuration. (IF we had more than one configurations) ==5
0x00, //index of string descriptor for this configuration ==6
0xC0, //bit 6=1 if self powered, bit 5=1 if supports remote wakeup (we don't), bits 0-4 unused and bit7=1 ==7
0x32, //maximum bus power required (maximum milliamperes/2) (0x32 = 100mA) //8
//interface descriptor 1 (NES Controller A)
USB_DESC_INTERFACE_LEN, //length of descriptor =9
USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04) =10
0x00, //number defining this interface (IF we had more than one interface) ==11
0x00, //alternate setting ==12
1, //number of endpoints for this interface //13
0x03, //class code, 03 = HID ==14
0x01, //subclass code //boot ==15
0x02, //protocol code ==16
0x02, //index of string descriptor for interface ==17
//class descriptor 1 (HID)
USB_DESC_CLASS_LEN, //length of descriptor ==18
USB_DESC_CLASS_TYPE, //dscriptor type (0x21 == HID) ==19
0x00,0x01, //hid class release number (1.0) (try 1.10) ==20,21
0x00, //localized country code (0 = none) ==22
0x01, //number of hid class descrptors that follow (1) ==23
0x22, //report descriptor type (0x22 == HID) ==24
USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][0], 0x00, //length of report descriptor ==25,26
//endpoint descriptor 1
USB_DESC_ENDPOINT_LEN, //length of descriptor ==27
USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05) ==28
0x81, //endpoint number and direction (0x81 = EP1 IN) ==29
USB_ENDPOINT_TYPE_INTERRUPT, //transfer type supported (0x03 is interrupt) ==30
USB_EP1_TX_SIZE,0x00, //maximum packet size supported ==31,32
10, //polling interval, in ms. (cant be smaller than 10 for slow speed devices) ==33
//interface descriptor 2 (NES Controller B)
USB_DESC_INTERFACE_LEN, //length of descriptor =34
USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04) =35
0x01, //number defining this interface (IF we had more than one interface) ==36
0x00, //alternate setting ==37
1, //number of endpoints for this interface //38
0x03, //class code, 03 = HID ==39
0x01, //subclass code //boot ==40
0x02, //protocol code (keyboard) ==41
0x03, //index of string descriptor for interface ==42
//class descriptor 2
USB_DESC_CLASS_LEN, //length of descriptor ==43
USB_DESC_CLASS_TYPE, //dscriptor type (0x21 == HID) ==44
0x00,0x01, //hid class release number (1.0) (try 1.10) ==45,46
0x00, //localized country code (0 = none) ==47
0x01, //number of hid class descrptors that follow (1) ==48
0x22, //report descriptor type (0x22 == HID) ==49
USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][1], 0x00, //length of report descriptor ==50,51
//endpoint descriptor 2 IN
USB_DESC_ENDPOINT_LEN, //length of descriptor ==52
USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05) ==53
0x82, //endpoint number and direction (0x81 = EP1 IN) ==54
USB_ENDPOINT_TYPE_INTERRUPT, //transfer type supported (0x03 is interrupt) ==55
USB_EP2_TX_SIZE,0x00, //maximum packet size supported ==56,57
10 //polling interval, in ms. (cant be smaller than 10 for slow speed devices) ==58
//****** BEGIN CONFIG DESCRIPTOR LOOKUP TABLES ********
//since we can't make pointers to constants in certain pic16s, this is an offset table to find
// a specific descriptor in the above table.
//NOTE: DO TO A LIMITATION OF THE CCS CODE, ALL HID INTERFACES MUST START AT 0 AND BE SEQUENTIAL
// FOR EXAMPLE, IF YOU HAVE 2 HID INTERFACES THEY MUST BE INTERFACE 0 AND INTERFACE 1
#define USB_NUM_HID_INTERFACES 2
//the maximum number of interfaces seen on any config
//for example, if config 1 has 1 interface and config 2 has 2 interfaces you must define this as 2
#define USB_MAX_NUM_INTERFACES 2
//define how many interfaces there are per config. [0] is the first config, etc.
const char USB_NUM_INTERFACES[USB_NUM_CONFIGURATIONS]={2};
//define where to find class descriptors
//first dimension is the config number
//second dimension specifies which interface
//last dimension specifies which class in this interface to get, but most will only have 1 class per interface
//if a class descriptor is not valid, set the value to 0xFFFF
const int16 USB_CLASS_DESCRIPTORS[USB_NUM_CONFIGURATIONS][2][1]=
//config 1
//interface 0
//class 1
18,
//interface 1
//class 1
43
//****** END CONFIG DESCRIPTOR LOOKUP TABLES ********
#if (sizeof(USB_CONFIG_DESC) != USB_TOTAL_CONFIG_LEN)
#error USB_TOTAL_CONFIG_LEN not defined correctly
/// start device descriptors
const char USB_DEVICE_DESC[] = {
//starts of with device configuration. only one possible
USB_DESC_DEVICE_LEN, //the length of this report ==1
0x01, //the constant DEVICE (DEVICE 0x01) ==2
0x10,0x01, //usb version in bcd (pic167xx is 1.1) ==3,4
0x00, //class code ==5
0x00, //subclass code ==6
0x00, //protocol code ==7
USB_MAX_EP0_PACKET_LENGTH, //max packet size for endpoint 0. (SLOW SPEED SPECIFIES 8) ==8
0x61,0x04, //vendor id (0x04D8 is Microchip, or is it 0x0461 ??)
0x4C,0x00, //product id ==11,12 //don't use ffff says usb-by-example guy. oops
0x00,0x01, //device release number ==13,14
0x01, //index of string description of manufacturer. therefore we point to string_1 array (see below) ==15
0x01, //index of string descriptor of the product ==16
0x00, //index of string descriptor of serial number ==17
USB_NUM_CONFIGURATIONS //number of possible configurations ==18
#if (sizeof(USB_DEVICE_DESC) != USB_DESC_DEVICE_LEN)
#error USB_DESC_DEVICE_LEN not defined correctly
/// start string descriptors
/// String 0 is a special language string, and must be defined. People in U.S.A. can leave this alone.
//the offset of the starting location of each string. offset[0] is the start of string 0, offset[1] is the start of string 1, etc.
const char USB_STRING_DESC_OFFSET[]={0,4,24,78};
//number of strings you have, including string 0.
#define USB_STRING_DESC_COUNT sizeof(USB_STRING_DESC_OFFSET)
char const USB_STRING_DESC[]={
//string 0
4, //length of string index
USB_DESC_STRING_TYPE, //descriptor type 0x03 (STRING)
0x09,0x04, //Microsoft Defined for US-English
//string 1
20, //length of string index
'Z',0,
'e',0,
'r',0,
'o',0,
'-',0,
'S',0,
'o',0,
'f',0,
't',0,
//string 2
54, //length of string index
'Z',0,
'e',0,
'r',0,
'o',0,
'-',0,
'S',0,
'o',0,
'f',0,
't',0,
' ',0,
'N',0,
'E',0,
'S',0,
' ',0,
'C',0,
'o',0,
'n',0,
't',0,
'r',0,
'o',0,
'l',0,
'l',0,
'e',0,
'r',0,
' ',0,
'A',0,
//string 3
'Z',0,
'e',0,
'r',0,
'o',0,
'-',0,
'S',0,
'o',0,
'f',0,
't',0,
' ',0,
'N',0,
'E',0,
'S',0,
' ',0,
'C',0,
'o',0,
'n',0,
't',0,
'r',0,
'o',0,
'l',0,
'l',0,
'e',0,
'r',0,
' ',0,
'B',0
