alexshadow
| regards to everyone,i need some help WITH SMS AT COMMAND !!! |
Posted: Thu Dec 22, 2005 2:26 pm |
hi i have this source code from an keypad project that stores the pressed keys into eeprom,but i need to be sent through sms with an nokia 6230 phone,can anyone help me about the AT command and to modifi this,REGARDS
#include "16F876.h"
#device *=16
#device adc=8
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
#include "24256.c"
#fuses NOWDT,HS, NOPUT, NOPROTECT, NOBROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG
#include "myKBD.c"
#use fast_io(B)
static const byte ID = 1;
static char kb[70];
static byte seconds, minutes, hours, a1, a2, a3, kb_count;
static char b, c, rnd;
static boolean w, auth;
static unsigned int32 i, ticks, counter, pointer, offset, temp;
#int_rtcc
clock_isr() {
ticks++;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_timer_1(T1_DISABLED);
setup_counters(RTCC_INTERNAL, RTCC_DIV_256);
setup_spi(FALSE);
set_tris_b(0b00001111);
set_tris_c(0b10010100);
port_b_pullups(TRUE);
kbd_init();
set_rtcc(0);
enable_interrupts(INT_RTCC);
init_ext_eeprom();
ticks = make32(read_eeprom(0), read_eeprom(1), read_eeprom(2), read_eeprom(3));
pointer = make32(read_ext_eeprom(0), read_ext_eeprom(1));
offset = make32(read_ext_eeprom(2), read_ext_eeprom(3));
auth = FALSE;
kb_count = 0;
output_high(LED); delay_ms(100);
output_low(LED); delay_ms(100);
output_low(LED);
while (1) { // main loop
if (ticks % 100 == 0) {
i = ticks;
write_eeprom(3, i % 256);
i = i >> 8;
write_eeprom(2, i % 256);
i = i >> 8;
write_eeprom(1, i % 256);
i = i >> 8;
write_eeprom(0, i);
if (kbhit()) {
c = getc();
if (c == 'a') {
rnd = getc();
temp = ticks;
putc(rnd ^ 170 ^ ID);
putc( 85 ^ (temp % 256));
putc(rnd ^ 170 ^ (offset / 256));
putc(rnd ^ 85 ^ (offset % 256));
putc(rnd ^ 170 ^ (pointer / 256));
putc(rnd ^ 85 ^ (pointer % 256));
if (c == 'A') {
a1 = getc() ^ rnd;
a2 = getc() ^ rnd;
a3 = getc() ^ rnd;
if ((a1 == ID ^ (temp % 256)) &&
(a2 == (pointer / 256) ^ (pointer % 256)) &&
(a3 == (offset / 256) ^ (offset % 256))) {
auth = TRUE;
putc('1');
} else { putc('0'); auth = FALSE; }
if (c == 'v') {
if (auth) {
putc(offset / 256);
putc(offset % 256);
i = 4;
if (pointer > 0)
while (1) {
putc(read_ext_eeprom(i));
i++;
if (i >= offset) break;
auth = FALSE;
if (c == 'f') {
write_ext_eeprom(0, 0);
write_ext_eeprom(1, 0);
write_ext_eeprom(2, 0);
write_ext_eeprom(3, 4);
for (i = 4; i < EEPROM_SIZE; i++)
write_ext_eeprom(i, 0);
putc('1');
auth = FALSE;
if (c == 's') {
auth = FALSE;
pointer = 0;
offset = 4;
delay_ms(15);
delay_ms(15);
delay_ms(15);
delay_ms(15);
if ((read_ext_eeprom(0) == 0) && (read_ext_eeprom(1) == 0) &&
(read_ext_eeprom(2) == 0) && (read_ext_eeprom(3) == 4)) putc('1'); else putc('0');
if (c == 'r') {
ticks = 0;
write_eeprom(0, 0);
write_eeprom(1, 0);
write_eeprom(2, 0);
write_eeprom(3, 0);
if ((read_eeprom(0) == 0) && (read_eeprom(1) == 0) &&
(read_eeprom(2) == 0) && (read_eeprom(3) == 0)) putc('1'); else putc('0');
output_low(LED);
c = kbd_getc();
if (c != 0) {
i = ticks / 76.29339453125;
hours = i / 3600;
i = i % 3600;
minutes = i / 60;
seconds = i % 60;
write_ext_eeprom(offset, 1);
offset++;
write_ext_eeprom(offset, c ^ hours ^ minutes ^ seconds);
offset++;
write_ext_eeprom(offset, hours);
write_ext_eeprom(offset + 1, minutes);
write_ext_eeprom(offset + 2, seconds);
offset += 3;
pointer++;
write_ext_eeprom(0, pointer / 256);
write_ext_eeprom(1, pointer % 256);
write_ext_eeprom(2, offset / 256);
write_ext_eeprom(3, offset % 256);
output_low(LED);
jds-pic
Posted: Thu Dec 22, 2005 3:19 pm |
all you need to do to make the change you are requesting is add this line to the top of your file:
#include "Nokia_6230_SMS_AT_driver.h"
the compiler will take care of the rest.
happy holidays,
jds-pic |
jaime
Joined: 25 Nov 2005 Posts: 56 Location: Porto - Portugal
Posted: Fri Dec 23, 2005 5:28 am |
Hello
"#include "Nokia_6230_SMS_AT_driver.h" ????
Where are this library???
thanks
Jaime |
alexshadow
Posted: Fri Dec 23, 2005 2:57 pm |
| thank you very much for your help but where i can find this #include "Nokia_6230_SMS_AT_driver.h |
Posted: Fri Dec 23, 2005 3:32 pm |
The guy who posted that was making a joke.
(Normally we don't reply in that way on this forum,
but he did that in this particular case). |
JBM
Joined: 12 May 2004 Posts: 54 Location: edinburgh, Scotland
Posted: Fri Dec 23, 2005 6:26 pm |
If all you want to do is send a text message to a number, the syntax is very simple indeed:
| Code: | printf("AT+CMGS=%s",phone_number);
putc(13);
printf("%s",body_of_text_message);
putc(13);
putc(26); |
where phone_number and body_of_text_message are pointers (array names) of where the appropriate data is stored. I once spent a week tearing my hair out because a colleague was treating the phone number as a 'number', rather than a string of characters. Don't fall into that trap!
The outgoing text string might look something like this, if you viewed it in hypertrm:
AT+CMGS=07246123456
This is an inane text message! yay!
From memory putc(26); is done with Ctrl+z in hypertrm, but it's been a month or two since i spoke 'directly' to a modem.
hope this helps
-JBM |
alexshadow
| THANK YOU |
Posted: Mon Dec 26, 2005 2:10 pm |
| THANK YOU VERY MUCH JBM,REGARDS AND HAPPY HOLLIDAY |
JBM
Posted: Mon Dec 26, 2005 2:11 pm |
| And to you too. |
DragonPIC
Posted: Tue Dec 27, 2005 11:04 am |
| PCM programmer wrote: | The guy who posted that was making a joke.
Is it April already? _________________ -Matt |
HuaWuQue
Posted: Mon Mar 27, 2006 5:09 am |
| JBM wrote: |
putc(13);
putc(13);
putc(26); |
wat's the number 13 and 26 means?
how to determine wat number should put inside the bracket? |
Posted: Mon Mar 27, 2006 5:21 am |
Those are ASCII values. Check http://en.wikipedia.org/wiki/ASCII
13 = Carriage Return (CR), used for going to the next line (the 'enter' key on your keyboard)
26 = substitute (SUB), but also the key combination ctrl-z
Check the manual of your modem where all AT-commands are described for when and how to send these characters. |
