dongSORRY for reversal) Guest
| LCD gets stuck(hd44780) |
Posted: Fri Mar 24, 2006 6:11 pm |
hello all, (sorry for reversal of name n topic)
(me posting it again.
sorry if i m troubling with many posts.)
this is dong again.one question.
The problem : According to code LCD should keep displaying
"Dong the king" till it gets 8 bit input.But it doesnot wait for the input for more than 2 seconds.If it gets input in 2 seconds it shows the points.
otherwise it keeps showing "dong the king"(it gets STUCK here)
what i do??
The same is problem from "hello" to input from PIN D0.if it gets input in 1-2 seconds, it moves forward ; otherwise gets stuck at "hello".
is there a way lcd keeps waiting for the inputs.??(and not get stuck)
Dong
--------------------------------My code--------------------------------------
lcd_init();
printf(lcd_putc,"hello!!!");
while(input(pin_D0))
lcd_init();
lcd_init();
printf(lcd_putc,"dong the king");
delay_ms(1000);//new
dong= input_b();
while(dong != 255)//My lcd doesnot wait for this for long.it gets stuck.
if(points = dong & 0x7F;)
printf(lcd_putc,"%u",points);
Posted: Fri Mar 24, 2006 6:30 pm |
See section 2.2 in this webpage:
http://www.drpaulcarter.com/cs/common-c-errors.php
Ideally, you would learn this in the classroom. The purpose of
this forum is not to teach the C language. Most people do not
want to answer questions that are about beginner's coding errors.
Also, you should not make multiple posts of the same question,
with each post done with a different "guest" name. |
