Sigma
| 18F6622 ICD problem with compiler version 3.236 |
Posted: Wed Mar 22, 2006 8:15 pm |
Dear all,
I am using compiler version 3.236, pic18f6622 for my development.
Yesterday I had problem burning in the code, then i search in the forum, and found http://www.ccsinfo.com/forum/viewtopic.php?t=25924&highlight=18f6622 .I changed accordingly as ckielstra mentions.
Then the code can be burned into the chip.
But today when i try to use the ICD emulation mode, it prompts 'The detected target name:PIC18F6622 does not match the code's target: PIC16C622. Do you want to continue?' If i click 'yes', after some time, it would say 'Could not start target..... check MCLR and ocsillator' etc.
Can anyone help?
Thanks in adv.
Sigma |
Sigma
Posted: Thu Mar 23, 2006 3:35 am |
I have checked the hardware connection, and they are okay. MCLR at 5 volt. IAR firmware version: 1.39 I can use iar.exe to program the chip, and it is working. But if i want to use the debug mode, it prompt the errors.
What i burn is
#include "18f6622.h"
#device *=16 ICD=TRUE
#fuses PROTECT=15
#fuses WRT=15
#fuses EBTR=15
main()
The list file is:
CCS PCH C Compiler, Version 3.236, 30957 23-Mar-06 18:41
Filename: C:\Documents and Settings\demo1\Desktop\New Folder\test.LST
ROM used: 26 bytes (0%)
Largest free fragment is 64678
RAM used: 5 (0%) at main() level
5 (0%) worst case
Stack: 0 locations
0000: GOTO 0004
.................... #include "18f6622.h"
.................... //////// Standard Header file for the PIC18F6622 device ////////////////
.................... #device PIC18F6622
.................... #list
.................... #device *=16 ICD=TRUE
.................... #fuses PROTECT=15
.................... #fuses WRT=15
.................... #fuses EBTR=15
.................... main()
0004: CLRF FF8
0006: BCF FD0.7
0008: CLRF FEA
000A: CLRF FE9
000C: MOVF FC1,W
000E: ANDLW C0
0010: IORLW 0F
0012: MOVWF FC1
0014: MOVLW 07
0016: MOVWF FB4
0018: BRA 0018
Configuration Fuses:
Word 1: 0F00 NOIESO NOFCMEN RESERVED
Word 2: 1E19 NOBROWNOUT NOWDT BORV25 NOPUT WDT32768
Word 3: 81F3 CCP2C1 NOLPT1OSC MCLR RESERVED
Word 4: 0000 NOSTVREN DEBUG NOLVP NOXINST BBSIZ1K RESERVED
Word 5: C00F NOPROTECT NOCPD NOCPB
Word 6: E00F NOWRT NOWRTD NOWRTC NOWRTB
Word 7: 400F NOEBTRB NOEBTR
the hex code is
:020000040000FA
:1000000002EF00F0F86AD09EEA6AE96AC150C00BBC
:0A0010000F09C16E070EB46EFFD792
:020000040030CA
:0E000000000F191EF38100000FC00FE00F402B
:00000001FF
;PIC18F6622
When i remove the 'ICD = TRUE' in the c code
#device *=16
#fuses PROTECT=15
#fuses WRT=15
#fuses EBTR=15
main()
After compilation, the list file is
CCS PCH C Compiler, Version 3.236, 30957 23-Mar-06 18:29
Largest free fragment is 65510
5 (0%) worst case
Stack: 0 locations
0000: GOTO 0004
0004: CLRF FF8
0006: BCF FD0.7
0008: CLRF FEA
000A: CLRF FE9
000C: MOVF FC1,W
000E: ANDLW C0
0010: IORLW 0F
0012: MOVWF FC1
0014: MOVLW 07
0016: MOVWF FB4
0018: SLEEP
Word 2: 1F1F BROWNOUT WDT BORV25 NOPUT WDT32768
Word 4: 0085 STVREN NODEBUG LVP NOXINST BBSIZ1K RESERVED
the hex code is
:020000040000FA
:0A0010000F09C16E070EB46E030065
:020000040030CA
:0E000000000F1F1FF38185000FC00FE00F409F
:00000001FF
;PIC18F6622
Can anyone help?
Thanks.
Sigma[/quote] |
Humberto
Posted: Thu Mar 23, 2006 6:37 am |
| Quote: |
This message appears every time the ICD cannot raise MCLR pin over 5V,
so I guess you have a hardware problem.
Do you have connected the R that separates the ICD from the MCLR?
Humberto |
Sigma
Posted: Thu Mar 23, 2006 8:20 am |
Thanks Humberto. I know this famous problem of ICD 'can not start target......' But i would say this one i encountered is not the same problem. It is giving another problem before getting this one. The main problem is that there is mismatch between the compiler recognition and the ICD recognition of the chip. It said 'The detected target name:PIC18F6622 does not match the code's target: PIC16C622. Do you want to continue?' To me, it seems like the ICD detects a 18F6622 while the compiler see it as a 16C622. But my code is
#fuses PROTECT=15
#fuses WRT=15
#fuses EBTR=15
main()
How can it be possible?! you see.
Please help.
Sigma |
Sigma
Posted: Thu Mar 23, 2006 7:05 pm |
It seems like few people using 18F6622. But could anyone using this chip compile my sample program and try to see whether it will work on bebug mode using your compiler? If anyone have any suggestion, i will be glad to try it.
Thanks.
Sigma |
ckielstra
Posted: Fri Mar 24, 2006 5:09 pm |
It seems that setting ICD=TRUE changes more fuses than just the debugger enable fuse. The changed fuses in your example program are:
- NOBROWNOUT
- NOWDT
- NOSTVREN (Stack full/underflow reset enable bit)
- DEBUG
- NOLVP
Changing these fuses makes sense for the debugger.
Also check the readme.txt for the ICD2 debugger in the Microchip MPLAB directory or at http://ww1.microchip.com/downloads/en/DeviceDoc/ReadmeMP731.zip
Especially note the tip for setting the NOPUT fuse when using the ICD on a PIC18F6622 chip.
I don't see any errors in the list file. The error message for a PIC18C6622 detected is strange, could this be an error in your IAR software? |
Sigma
Posted: Fri Mar 24, 2006 6:49 pm |
Thanks, ckielstra.
The list file and hex file seem no problem. But in the .cof.txt file, i am surprised to find the following lines:
Optional Header:
magic=7032
vstamp=12854
proc_type=0x00006622 [PIC16C622]
rom_width_bits=8
ram_width_bits=8
I found another link in the forum http://www.ccsinfo.com/forum/viewtopic.php?t=17208
A few more people share the similar problem, and remain unsolved, though.
Thanks.
Sigma |
