handsprince
Project need help |
Posted: Thu Mar 16, 2006 8:00 am |
i'm doing the project :- receive signal from LM35DZ sensor then store the temperature, time and date into MMC card,after that send the data to computer via rs232 interface with VB language. if can i want to display the temperature graph using microsoft excel. anyone can give me advice or example??? thank for your kindness
rwyoung
Posted: Thu Mar 16, 2006 1:47 pm |
You can't be serious, can you?
"teach me how to write the program", isn't that what your are supposed to be learning in class by doing your own homework? _________________ Rob Young
handsprince
sorry!!! |
Posted: Thu Mar 16, 2006 9:12 pm |
Can you give me an example???sorry for my last posted |
Mark
Posted: Thu Mar 16, 2006 10:05 pm |
This isn't a VB programming forum. But if you are trying to figure out how to create an excel spreadsheet from VB and populate some data then hear is an example. Study it all you want but don't ask questions about it in this forum. There are VB forums out there where you can find this kind of information.
Private Sub Export()
Dim rstData As Recordset
Dim rstTime As Recordset
Dim mycriteria As String
Dim rstChannel As Recordset
Dim x As Integer
Dim y As Integer
Dim data() As Single
Dim starttime As Date
Dim i As Long
pbImport.Value = 0
'Make sure that the database is opened
If db Is Nothing Then
MsgBox "Database not opened.", vbExclamation, "No Database"
pbImport.Visible = False
Exit Sub
End If
'Setup an excel file
Dim xlApp As Excel.Application
Dim xlBook As Excel.Workbook
Dim xlSheet As Excel.Worksheet
'Create the excel file
Set xlApp = CreateObject("Excel.Application")
Set xlBook = xlApp.Workbooks.Add
Set xlSheet = xlBook.Worksheets(1)
'Create the title
xlSheet.Cells(2, 2).Value = txtTitle
xlSheet.Range("B2:K2").HorizontalAlignment = 7
'Create a recordset for each distinct time sample
mycriteria = "SELECT DISTINCT Time FROM [Test Data] ORDER BY Time"
Set rstTime = db.OpenRecordset(mycriteria, dbOpenDynaset)
With rstTime
If Not (.EOF And .BOF) Then
'Populate recordset
.MoveLast
.MoveFirst
Else
MsgBox "No data to work with.", vbExclamation, "No Data"
Exit Sub
End If
End With
'Setup some status info
y = 1
Label1 = "Creating Excel headings..."
pbImport.Max = List.ListCount + 1
'Add the time column heading
xlSheet.Cells(3, y).Value = "Time, min."
'Add the channel column headings
For i = 0 To List.ListCount - 1
If List.Selected(i) Then
pbImport.Value = y
y = y + 1
xlSheet.Cells(3, y).Value = List.List(i)
End If
DoEvents
Next i
'Add the time data
With rstTime
'-- First we will export the "Float" value
x = 4 'Start on the fourth row
Label1 = "Creating Excel row " + Format(x - 4, "0") + " of " + _
Format(.RecordCount, "0") + "..."
y = 1 'Column one
pbImport.Max = List.SelCount + 1
ReDim data(List.SelCount + 1)
data(y) = 0
'Get the data base on the time
mycriteria = "SELECT * FROM [Test Data] WHERE Time = #" + _
Format(.Fields("Time")) + "#ORDER BY Channel"
Set rstData = db.OpenRecordset(mycriteria, dbOpenDynaset)
'Store the data in an array
pbImport.Value = y
y = y + 1
mycriteria = "Channel = " + Format(List.ItemData(i), "0")
rstData.FindFirst mycriteria
If rstData.NoMatch Then
data(y) = 0
Else
data(y) = rstData.Fields("Voltage")
End If
End If
DoEvents
Next i
'Add the data to the spreadsheet
xlSheet.Range(xlSheet.Cells(x, 1), xlSheet.Cells(x, y)).Value = data
xlSheet.Cells(x, 1).Value = "Float"
'Continue with the next time's data
x = x + 1
.MoveNext
'-- This is the data - store the first time so that we can display delta t
If Not .EOF Then
starttime = .Fields("Time")
End If
'Do the rest of the data
Do While Not .EOF
'Tell the user what we are doing
y = 1
'Store the time as the first element
data(y) = (.Fields("Time") - starttime) * 1440
'Get the data for this time
'Load the data into the array
pbImport.Value = y
y = y + 1
'No data
data(y) = 0
Else
'Found data
End If
End If
DoEvents
Next i
x = x + 1
.MoveNext
Loop
End With
'We are done
Label1 = "Saving file..."
'Now we need to save the file
Save_Again:
Do
Err = 0
On Error Resume Next
'Get a file name
CommonDialog.CancelError = True
CommonDialog.DefaultExt = ".xls"
CommonDialog.Filter = "Excel (*.xls)|*.xls"
CommonDialog.filename = ""
CommonDialog.Flags = cdlOFNCreatePrompt Or cdlOFNExplorer
CommonDialog.ShowSave
'Make sure that the user didn't cancel
If Err = cdlCancel Then Exit Do
'Make sure that the file does not exist
If Dir(CommonDialog.filename) <> "" Then
MsgBox "Please select a new file name.", vbExclamation, "Save As"
End If
Loop While Dir(CommonDialog.filename) <> ""
If Err <> cdlCancel Then
On Error GoTo Export_Error
'Save the file
xlSheet.SaveAs CommonDialog.filename
' Close Excel with the Quit method on the Application object
xlApp.Quit
End If
Label1 = ""
' Release the object variables
Set xlApp = Nothing
Set xlBook = Nothing
Set xlSheet = Nothing
'Close up
rstData.Close
rstTime.Close
MsgBox "File saved as " + CommonDialog.filename, vbInformation, "Success"
Exit Sub
Export_Error:
'Methodname method of classname class failed
If Err = 1004 Then GoTo Save_Again
'Another error occured
MsgBox Error$(Err), vbExclamation
Set xlApp = Nothing
Label1 = ""
Exit Sub
End Sub
